Post by tlight on Feb 24, 2011 16:16:13 GMT
All holes (that we can think of) have been drilled, prior to powder coating... The lorry collects the chassis @ 8am in the morning for powder coating, next picture will be of a nice shiny signal red chassis !
Post by bobsox on Feb 24, 2011 21:54:32 GMT
I can't wait to see the chassis in red Tim, it's going to look awesome!
Post by tlight on Feb 25, 2011 8:31:13 GMT
Got up early & added a few more holes along the top of the engine bay bulkhead after seeing Alex's updated photos last night (the neighbors will love me). Powder coaters arrived bang on time, chassis due back early next week....
Post by Deleted on Feb 25, 2011 11:02:35 GMT
Tim, good progress. Looking forward to seeing the powdercoat in red! I recon I've drilled about 300 holes in total, as it's impossible to get the right placement first time, luckily with brake hoses and fuel lines etc theyre all covered and out of sight. It's a case of fitting things as you go along and moving them around as other things are fitted like wiring and lines. I decided to carpet the aluminium as it's so soft and got covered in dirt and scratches and was full of incorrectly drilled holes!! Advice would be either cover it during the build or take it out once fitted. When's the frame due back?
Post by tlight on Feb 26, 2011 7:09:23 GMT
Alex,
Jospeh recons we have drilled circa 200-300 holes. Fingers crossed frame should be back Tuesday. Will post a pic as soon as...
Tim
hag
Newbie
Post by hag on Feb 28, 2011 0:07:33 GMT
This is a fantastic build thread Tim and Joseph, as a newbie, it's inspirational and informative.
I shall be following this with great interest;)
Andy888
Exocet Builder
Post by Andy888 on Feb 28, 2011 0:17:39 GMT
That's an awful lot of holes!!! Is there any advantage/disadvantage to doing all that prior to powdercoating?
Post by tlight on Feb 28, 2011 7:57:43 GMT
Reduce the risk of scratching the nice fresh powder coat in build process.
Plus no break to the powder coating (rust leaching) - though I doubt it will see much exposure to rain water...
Tim
Post by tlight on Mar 1, 2011 11:07:20 GMT
The chassis has returned from Phoenix Engineering, powder coated signal red; Rear...
hag
Newbie
Post by hag on Mar 1, 2011 11:38:45 GMT
Looks great, can't wait to see the finished article, some thread;)
Post by Kevin Patrick on Mar 1, 2011 14:31:36 GMT
Love the frame in red, Tim!
Post by tlight on Mar 1, 2011 15:12:45 GMT
Kevin. Thanks, just come home to find the postman has delivered the 4off isolator bobbins.... 6" ruler along side, with & without M10 nuts added a nut either end prior to fitment, which made it about 55mm clearance (I reconed I only needed around 40mm). the stud length, though quite long for what I need, is not visible from the rear (think I'll leave long at the moment as it may aid as a pick-up point for a harness p clip). and the isolators make a nice tidy job. Tim
Post by Stiggy on Mar 1, 2011 17:14:29 GMT
Very smart. Look forward to seeing the grp on or near
Post by AdeEp23 on Mar 1, 2011 20:58:25 GMT
Yeah the frame looks great in red cant wait to see it all assembled
Post by tlight on Mar 1, 2011 22:25:23 GMT
Riv Nut gun, applied to front cross member for radiator mounting Joseph fitting them in the engine bay for the harness and brake pipe P clips. Passenger floor riveting, after application of silicon sealant. Sides (best white on red I could do tonight Stuart !)
