Post by Fin on Sept 24, 2016 9:12:23 GMT
Question for people using mk2 mx5s, does the 2015/2016 MeV chassis still not line up with the mx5 without modifying it? I'm just awaiting bushes and suspension back from powder-coating, prior to starting to re-assemble, and was wondering the same. Normal route seems to build the skate, drop the chassis on, and then "fettle it" so it fits and is square. I was wondering if there was any benefit in fitting the sub-frames individually to the chassis, and then fitting the PPF, prop shaft & engine, and then building the suspension wheel by wheel?
Post by mikeeyboy on Sept 24, 2016 13:05:04 GMT
I have the skate as 1 piece, using the engine hoist I have it was pretty easy to get all the rear bolts and fronts to drop in.
I've just done it this morning. I noticed that it looked more like trident made a bracket to get the subframe brace bar to reach the Exocet chassis?
Post by Fin on Sept 24, 2016 14:01:27 GMT
There's a 1 metre long U shaped tubular bracket from the rear sub to the bodywork on the 2.5
Post by mikeeyboy on Sept 24, 2016 17:42:49 GMT
I'm confused then. I thought mine was a mk2, I've got the 1 metre U Bracket. Mines a 98, thought mk2.5s were newer?
Post by Fin on Sept 24, 2016 17:56:37 GMT
Maybe the Mk2's also have it. Either way, the build manual doesn't recognise it as it refers to 14 bolts holding the body, not 16.
Post by mikeeyboy on Sept 24, 2016 18:29:05 GMT
Might give Stuart a ring on Monday to clear it up then!
I put the u bracket up to the car and 2 of the bolts end up near the seats!
Post by Fin on Sept 24, 2016 19:26:44 GMT
Can you let me know the outcome?
Post by mikeeyboy on Sept 24, 2016 19:50:04 GMT
No problem, will post on here what he says!
Post by stevednorris on Sept 25, 2016 10:42:09 GMT
I chopped the front half of the U bracket off and fitted it with just 4 bolts (on a Replicar but basically the same chassis), mines a mk2.5 and fitted straight on the ppf.
Post by mikeeyboy on Sept 27, 2016 15:33:54 GMT
I spoke to Stuart today. He basically said the easiest way is to cut the "u" bracket from the mx5 short and flatten the round bar on the chopped ends.
Then drill a hole in each side and mount it to the flat metal tabs that are welded onto the Exocet chassis already.
I'm going to have a look at mine and decide whether to do this or use tridents L shaped bracket.
Thanks
Post by Fin on Sept 27, 2016 16:36:07 GMT
Thanks for letting me know. Does yours not already have 6 holes?
Post by mikeeyboy on Sept 27, 2016 16:39:10 GMT
Yep, but the open end of the U is way too long. You need to cut them a foot back
Post by Fin on Sept 27, 2016 18:39:53 GMT
OK, but surely the shorter you cut them, the less effective they are as a brace? Will go check Trident's alternative solution
Post by mikeeyboy on Sept 27, 2016 18:58:15 GMT
I'm not worried about it. As Stuart said, mk1s don't have it. That u bar is not exactly the biggest of things either, so I do not think it was totally structural.
trident
Improvise, Adapt and Overcome
Post by trident on Oct 3, 2016 19:42:34 GMT
The 1.8 on the Mk1 had the brace bar but the 1.6 MK1 didn't . I felt that if Mazda put the brace bar on the 1.8 then I was going to keep it as they put it there for a reason. Just my thought process at the time.
