Post by Shane on Jul 20, 2017 12:11:51 GMT
Bit of a drive mate near dudley
Will come some pics up for you later mate
Post by Shane on Jul 20, 2017 12:33:59 GMT
Post by p5curly on Jul 20, 2017 14:31:37 GMT
lol I fabricated a bracket to hold clocks in place using the lower holes on the clock
Post by Shane on Jul 20, 2017 14:32:53 GMT
Edited this comment, on wrong thread
Post by hutchey on Jul 20, 2017 14:33:23 GMT
lol I fabricated a bracket to hold clocks in place using the lower holes on the clock I have that in mind but dash doesn't really fit in the pod itself. Too loose or bad fitment
Post by p5curly on Jul 20, 2017 14:36:54 GMT
Bugger when did I post that I think we put a bracket on now to secure the pod Shane should have a pic of his it's fitted in a similar way
Post by Shane on Jul 20, 2017 14:38:08 GMT
Yeah, I will post pics of dash pod and nose cone hutchey when im back at the car.
Post by hutchey on Jul 24, 2017 19:53:21 GMT
Yeah, I will post pics of dash pod and nose cone hutchey when im back at the car. Cheers Shane, Did you keep the battery in the rear? I was looking to move it to under the dash but might leave it behind the drivers seat if I can find a decent box for it that's not stupidly expensive. I see you moved the MAF sensor for your custom air filter too, neat work that.
Post by Shane on Jul 24, 2017 19:56:28 GMT
Post by hutchey on Jul 25, 2017 16:16:30 GMT
Cheers, any joy with pics mate? The old threads have lost loads due to the photobucket fiasco
Post by Shane on Jul 25, 2017 16:20:47 GMT
Cheers, any joy with pics mate? The old threads have lost loads due to the photobucket fiasco I thought that photo bucket thing was just me! Tell me what pcitures you want mate and I will go out now and get a load for you!
Post by hutchey on Jul 25, 2017 17:11:31 GMT
Thanks Shane, that's fab.
The nose fitting and the MEV bracket Dash and how it fitted into the pod / mounted Air flow meter and the sensor / air filter Fuses and relay locations as mine wont stretch to where i see yours going to.
Massive thanks
Post by Shane on Jul 25, 2017 19:40:56 GMT
Thanks Shane, that's fab. The nose fitting and the MEV bracket Dash and how it fitted into the pod / mounted Air flow meter and the sensor / air filter Fuses and relay locations as mine wont stretch to where i see yours going to. Massive thanks
Post by hutchey on Jul 25, 2017 19:52:48 GMT
Shane, that's really superb. Me and the lad are really grateful. Did you have the charcoal canister thingy? I'm removing ours but there's a little connector that has some wires to it right at the pipes and I'm not sure if these need to be looped onto each other and the wire kept in place.
Post by Shane on Jul 25, 2017 20:01:04 GMT
Shane, that's really superb. Me and the lad are really grateful. Did you have the charcoal canister thingy? I'm removing ours but there's a little connector that has some wires to it right at the pipes and I'm not sure if these need to be looped onto each other and the wire kept in place. Just realised I forgot the bonnet hinge sorry, will take more tomorrow! I did alot of research into the charcoal canister and the consensus was to "bin it off" I think the connector your talking about is the EGR valve? Does the connector have a Mitsubishi logo on it? I was planning on keeping it to be on the safe side, but I cant see it anymore and I know dave has taken it off the 2 mevsters he has built and I have seen people say to get rid off it aswell, so i dont think its important for the general running of the car (bit like the charcoal canister)
