Post by franknbeans on Oct 16, 2015 19:07:15 GMT
New question. What's the measurements in between the wheel from front to back? Reason I am asking is I am considering buying one of these jack systems. www.quickjack.com/www.youtube.com/user/rangerquickjackI want to get the 5000 model to work with my Camaro, Solstice, Mazda3 and Ford Flex. But I am unsure if it would fit under the mevabusa.
Post by mawdo81 on Oct 18, 2015 16:17:02 GMT
Why would it matter if it was too long?
Post by mawdo81 on Oct 18, 2015 16:22:07 GMT
Just had a closer look. Due to the floor on the MeV you can put this inboard of the wheels and not worry re the length - a number of the guys in the uk use motorbike lifts, which are like a single one of these.
Post by johnp on Oct 18, 2015 17:30:09 GMT
260GBP ($400) linkdon't know if this, or similar, is available across the pond.
Post by kiwicanfly on Oct 18, 2015 20:58:38 GMT
I liked the look of the first one better.
Also I cannot see a solid lock on the second, whilst it is a mechanical lift via a screw thread I still would not be comfortable without a safety locking bar or similar. To be fair it might be present but I could not clearly tell.
Post by franknbeans on Oct 19, 2015 20:37:34 GMT
Ok cool. The lift I was going to get comes in a pair to lift a car that is maximum 5,000 lbs. So I think If I centered one under it might work like a bike ramp.
If not, there's nothing wrong with over kill.
Post by franknbeans on Nov 24, 2015 13:57:28 GMT
Stock Spedo with reverse gear.
How did everyone else do this? We had to cut the case to get the reverse gear in place. This then lead to the stock spedo that had the speed sensor from the crank no good.
Post by franknbeans on Nov 28, 2015 23:59:30 GMT
Post by franknbeans on Nov 30, 2015 3:48:07 GMT
Another question even though my last wasn't answered.
Can you guys show me how you are mounting the front bodywork to the frame.
Post by paulh on Nov 30, 2015 19:43:46 GMT
Got two aero catches on the top of mine. Not cheap but they work well.
Post by franknbeans on Dec 2, 2015 21:55:55 GMT
Paulh,
When you have a moment, can you get me some pictures of how you used the aero catches.
Thanks!
I'm still trying to sort out how I am gonna get the speedo to work after installing the reverse motor, bracket.
Post by franknbeans on Dec 17, 2015 16:42:50 GMT
Looking into a switch panel for the Busa. My plan is to use the car controls on the steering wheel for most things.. ie. Turn signals, Headlights Lights, parking lights Trying to figure out all the switches that I would need in addition. 1. Reverse Lights 2. Fan Override 3. 12v Outlet Was thinking about getting these and build a panel from the "dash" to the tunnel for mounting.
Post by mawdo81 on Dec 17, 2015 20:04:55 GMT
Why not wire the reverse lights to switch with the reverse? Why bother with a separate switch?
Where did you get the panel? Have you got a link please?
Post by james13009 on Dec 17, 2015 20:42:19 GMT
That's what I'm doing with the reverse.
Post by franknbeans on Dec 18, 2015 17:04:45 GMT
Ok, this is my idea with the reverse. Borrowed from another builder. Going to mount this switch under the dash that can be activated with my foot for reverse. The idea of having the reverse light on a separate switch... I can light up what I want is behind me before going backwards, not just when I am going backwards. Switch link. Thought about doing all the single switches that I've seen on other builds, but this would be a lot easier.
