Post by franknbeans on Jul 25, 2015 13:39:10 GMT
Thanks again guys...
I put down my deposit and finalizing the details of the kit.
Post by airforceone on Jul 25, 2015 17:40:13 GMT
Post by franknbeans on Jul 27, 2015 18:41:26 GMT
Thanks for the reply.
So is everyone running the stock gauge cluster or a electronic/ aftermarket one?
Post by paulh on Jul 27, 2015 18:57:17 GMT
Acewell aftermarket on mine
Post by Deleted on Jul 27, 2015 19:32:48 GMT
Etb digi dash on my busa powered Triabusa.
Post by franknbeans on Jul 28, 2015 18:42:56 GMT
Paulh & Adam,
Did you have any issues with the dashes? is it a plug and play or do you have to do a lot to get them to work right?
Post by Deleted on Jul 28, 2015 19:18:59 GMT
The digidash is pretty easy to set up. Comes with all its own sensors which I've fitted to the busa engine. Was just a case of plugging my laptop in and setting it up with the software that comes with it. Pretty easy all in all. All depends on what you want and what you want to monitor.
Post by franknbeans on Jul 28, 2015 20:05:22 GMT
Ok, thanks. Seems simple enough. I think it would just look cleaner that way than the stock gauge mounted in the middle of the dash.
Did you mount your behind the steering wheel? Pictures?
Post by Deleted on Jul 28, 2015 20:39:08 GMT
I mounted mine in the middle as the bubble on the bonnet is not central to my steering wheel. Would play havoc with my ocd having to mount it off Center. Must add my bonnet is the same as the exobusa
Post by franknbeans on Jul 29, 2015 19:50:19 GMT
Those shift buttons on your steering wheel?
Thanks for the picture.
Also, what are the buttons to the right of your cluster?
Post by Deleted on Jul 29, 2015 20:23:48 GMT
Yeah shift buttons. But have changed now to paddles.
Ones my horn button. Ones my reverse and ones for my oil cooler fan. I'm now removing the oil cooler fan and reverse so will be filling the holes when I get my front end sprayed.
Post by franknbeans on Jul 30, 2015 0:39:41 GMT
How about the button on the tunnel?
Post by Deleted on Jul 30, 2015 6:57:43 GMT
Push start
Post by franknbeans on Jul 30, 2015 14:20:51 GMT
aren't you slick! Thanks man... I can't wait to get mine started.
Going to ship either in the beginning of September or October.
Post by mawdo81 on Jul 30, 2015 19:37:45 GMT
Why so long? Thought it was a done deal for someone else? Is it not good to go?
