Post by franknbeans on Jul 30, 2015 20:10:12 GMT
Pete is going on vacation in August, I'm heading on vacation in September. I might have him deliver it the first week of September though.
Another question. Is anyone using Adjustable Proportioning brake valves on their cars? I had on on my track Miata so I didn't lock up the brakes in hard braking.
Post by mawdo81 on Jul 30, 2015 20:52:38 GMT
Unfortunately they're illegal on a road car in the UK but I think a number of track cars have them fitted.
Post by franknbeans on Aug 1, 2015 13:36:27 GMT
Ok, not sure about the legality of them in the US. Each state has their own regulations.
I'm very excited to get this started.. My guess is I'll have it done when there's four foot of snow on the ground. LOL
Post by franknbeans on Aug 4, 2015 21:07:14 GMT
Another question while i gather some things to get ready for the Busa kit.
I was planning on not doing a flappy paddle shifter. I was going to put the shifter on the tunnel. What kind of shifter is everyone using?
Post by moog on Aug 5, 2015 18:56:17 GMT
I haven't got that far yet, but I'm planning on a flappy paddle setup, partly because I've pretty much run out of room for a stick shift!
/Moog
Post by franknbeans on Aug 6, 2015 20:12:14 GMT
thanks for the heads up. Pete just informed me that even with the K.I.B. there will need to be fabrication work. Can anyone tell me the hardest fab work they have done on their kit?
I'm not much of a Fab guy, thus the KIB. I thought everything that I needed would be included in the kit.
Post by Deleted on Aug 6, 2015 20:34:52 GMT
There is no major fabrication work. Just simple stuff like mounting brackets.
Adam
Post by kiwicanfly on Aug 6, 2015 21:47:18 GMT
I bought the Rocket KIB but still had to do the fabrication, only real difference with KIB is you don't have to source things, you still have the same jobs to do.
The fabrication is not hard but care and patience is your best friend plus a few good tools.
Make trial panels with card before you cut the real panels.
Use fine blades on jig saws and support thin panels as close to the cut as possible.
Get a decent set of files.
Seek advice if you are not sure.
Use good quality drills and taps.
You will be fine.
Post by moog on Aug 7, 2015 12:24:03 GMT
I have the MEVExobusa KIB and yes there is fab work, like the above posts, so far it's mainly brackets such as that for the radiator, oil cooler, etc.
I was told there was no welding, and to be honest the welding required for the steering rack was pre-done which I was grateful for, but the exhaust needed some welding. Hopefully that's it now though.
/Moog
Post by franknbeans on Aug 12, 2015 16:52:51 GMT
thanks again guys.
I'm not much of a fabricator... But can find someone to help.
I think brackets should be easy to do though.
Post by franknbeans on Aug 12, 2015 18:30:41 GMT
I seen that a lot of the cars from the Exocet has a option of a steel floor. Would the Busa benefit from this? How sturdy is the aluminum floor?
Post by paulh on Aug 12, 2015 20:38:49 GMT
Plenty sturdy enough, and I'm 18 stone
Post by franknbeans on Aug 25, 2015 0:57:41 GMT
has anyone converted to a belt drive system?
Post by Deleted on Aug 25, 2015 7:36:48 GMT
99% sure no one has. Any particular reason why you might be considering it?
Adam
Post by franknbeans on Aug 25, 2015 15:19:00 GMT
My thoughts are:
1. They are quieter 2. No oiling the chain. 3. No oil splatter on the back of the car.
