Post by dietcoke on Sept 21, 2015 2:20:31 GMT
Electrical progress. Battery and main cables laid along with ground stud to 3/8" chassis point, as well as switch wired (1/0 welding cable).
Post by mawdo81 on Sept 21, 2015 6:50:47 GMT
Don't know about your regs, but in the UK you'd have to cover the + terminal and connector with an insulating boot or similar.
Love that bracket, home made?
Post by dietcoke on Sept 21, 2015 13:12:00 GMT
Ebay. I plan to cover the terminal with a boot eventually. I put studded marine terminals on it for ease of connect/disconnect, they're a little larger then automotive ones
Post by papabear on Sept 21, 2015 14:40:34 GMT
It's looking good dietcoke. Appreciate the pictures of the radiator mounts. I think your right 4 upper mounts may actually be a better solution for mounting the radiator to the front of the tubes. But the lower mount can be made to work.
Post by dietcoke on Sept 22, 2015 1:43:02 GMT
This is what four uppers looks like, certainly a little cleaner. I made it work with what I had. You might could request four uppers instead of two and two.
Post by pokeyhokie on Sept 22, 2015 12:05:18 GMT
This is what four uppers looks like, certainly a little cleaner. I made it work with what I had. You might could request four uppers instead of two and two. Is that XP-4 in the background? They have a loaner program now?
Post by greg on Sept 22, 2015 14:50:31 GMT
That's both XP5 and XP4. He was just using the picture as an example.
Post by pokeyhokie on Sept 23, 2015 11:08:52 GMT
That's both XP5 and XP4. He was just using the picture as an example. D'oh. I didn't even process that this wasn't his chassis, despite the obviously different color. I need more coffee.
Post by dietcoke on Sept 24, 2015 0:13:30 GMT
Been very busy and thus unmotivated after long days at work. I did get the new slave cylinder assembled with remote bleeder, and now have a working clutch. Will probably reinstall the trans mount and get on the brakes tomorrow.
Post by mawdo81 on Sept 24, 2015 17:25:10 GMT
Know the feeling, looking forward to doing some bits tonight though once the kids are in bed!
Post by papabear on Sept 24, 2015 18:03:50 GMT
Been very busy and thus unmotivated after long days at work. I did get the new slave cylinder assembled with remote bleeder, and now have a working clutch. Will probably reinstall the trans mount and get on the brakes tomorrow. I am right there with you. Work has been killing me lately with projects so I don't get to go out in the shop much. I am taking a week off next month to try and get some things done on the car. But you are making good progress and the car is looking really good.
Post by dietcoke on Sept 26, 2015 22:02:19 GMT
Brakes are bled and pedal is nice and firm, got main electrical finished, alternator and starter wired, starter tied into 12v bus bar I added to the engine bay. Alt is on its own 4awg circuit to cutoff switch. Wires are mounted in the tunnel and tucked out of the way. I'll get some pictures of it all tomorrow. Next project is wiring in the computer harness to the main electrical circuit, and making harnesses for the fans, ignition, and fuel pump. With a little motivation I might make my first trip up the road next week
Post by dietcoke on Oct 1, 2015 4:59:10 GMT
Not much doing, been very busy. Got a windshield cut and made up.
Post by jmills on Oct 1, 2015 22:37:46 GMT
What are the clamps you are using for the windshield? I may have to adapt a taller version from your and Greg's design. Any reason you both went with a low one vs. full height?
Post by greg on Oct 1, 2015 23:25:36 GMT
For me, I made it as short as the state would allow. Rather not have one at all honestly but it looks cool so its a compromise.
