Post by greg on Sept 13, 2015 3:52:03 GMT
I've been planning to add one. Especially since it seems the tiny oddessey battery dies in a weeks time from the draw of the RFID ignition.
Post by dietcoke on Sept 13, 2015 22:56:38 GMT
More work then it should have been, but it moves up enough for my wife to reach everything, and back enough for me to be comfortable. Just got to get the adjustable backbrace on, and belts, etc.
Post by dietcoke on Sept 14, 2015 23:49:32 GMT
Post by zeitgeist on Sept 15, 2015 21:20:28 GMT
Congrats on the progress and milestone. How tall is your wife? Looks like a ton of headroom with your seat and mount.
Post by dietcoke on Sept 15, 2015 21:28:47 GMT
she's 5 foot 3. i have about 3 inches above my helmet before the bars, and i'm 6'1
Post by einy on Sept 15, 2015 23:49:53 GMT
Looks great, man !! Congrats on the milestone!
Post by dietcoke on Sept 18, 2015 3:25:12 GMT
Wing pics. Very happy with the quality, this is a super nice piece. Was bleeding the clutch, and the bleeder unscrewed all the way and lost itself inside somewhere.... yep that's the end of today's work. The way the bleeder is setup is f@#$(@#&*$ stupid so I'm going to drop the trans and mount tomorrow, and install a remote bleeder, so I don't have to work in a 1 square inch space. Also will finish brakes and brake bleeding tomorrow, as the prop valve and other stuff should arrive.
Post by driver on Sept 18, 2015 18:20:58 GMT
Your car is going to sweet when finished!
Post by papabear on Sept 18, 2015 18:35:26 GMT
Do you have a picture of how you did your lower radiator mount? From some of the pictures it looks to not be mounted to anything. I have thought of mounting mine in the normal position and making a bracket from it to the radiator.
Post by dietcoke on Sept 18, 2015 20:33:46 GMT
I'll take a better picture for you in a few minutes. The best solution (in my opinion) would be four upper mounts, but this works just as well. All my electrical wire came today, so really taking the trans and driveshaft and mount out will just give me more space to hang stuff properly. It all works out I suppose.
Post by mdizz7 on Sept 18, 2015 20:56:12 GMT
How wide is the wing?
Post by dietcoke on Sept 18, 2015 22:17:04 GMT
The wing is as wide as the tires.
Post by dietcoke on Sept 19, 2015 0:53:12 GMT
Looks like the bleed on the slave straight snapped the hell off. Thats an expensive oops.
Post by dietcoke on Sept 20, 2015 0:52:00 GMT
No real update today, waiting on new slave cyl to come. I did finish dropping the trans, and removing the old slave. Got the backbrace on if that counts.
Post by boileralum on Sept 20, 2015 2:47:24 GMT
That's a bummer on the slave cylinder. At least you aren't swapping it in a snow covered driveway in February when it is 15* out, like the experience I had helping my buddy replace his on his 98 TransAm. What a PITA.
