Post by dietcoke on Dec 16, 2015 10:19:01 GMT
Also, here's a look of the new 7" swift front springs (550lb) vs the 5.5" 503lb VMaxx springs and helpers.
Post by einy on Dec 16, 2015 12:06:59 GMT
Where did you source the Makrolon from ?? I'm looking at covering up that same area, as you can see it when driving (and it kind of annoys me).
Post by dietcoke on Dec 16, 2015 13:00:50 GMT
Ebay! It's very inexpensive, relatively. They made all shapes and sizes, you'll need a 10x10 for each side
Post by einy on Dec 17, 2015 0:10:56 GMT
Cool ... Thanks
John
Post by dietcoke on Dec 17, 2015 14:11:45 GMT
Oil pressure weirdness is 100% gone, definitely had an oring issue. Glad thats fixed. Onto fitting the swift springs and to replace a leaky axle seal, and I think the car will be ready for the racetrack.
Post by greg on Dec 17, 2015 16:48:07 GMT
Excellent!
Now how to get my car to KS for some fun runs with you?
Post by dietcoke on Dec 17, 2015 21:19:28 GMT
I tow mine anywhere over about 30 miles.
Midterm project is now to design a functional splitter/front aero device to balance out the huge rear wing. Front wing is also an option/on the table, if mounts work out.
Post by dietcoke on Dec 18, 2015 2:18:37 GMT
Good view of the quality swift springs installed. Much better then that stupid helper setup that doesnt do anything on a short travel suspension.
Post by jmills on Dec 18, 2015 4:54:27 GMT
Let me know if you ever trailer that beast out to Illinois or Wisconsin. There are some great tracks out here to drive and race.
Post by dietcoke on Dec 22, 2015 7:41:56 GMT
I didn't test enough with the new O-Ring and as soon as I got the car up to temp the oil pressure issue popped back up, so I tore into the engine a little more and found the culprit. I should have replaced this originally when I went into the engine. The O-ring on the cam retainer plate was tore in two spots, it seals the oil galley between the cam and the mains, IE: it caused a HUGE pressure leak. Sure is easy to work on these LS motors in this car. Front of engine off, you can see the fresh oil pump and the large Q-Tip shaped oil galley above the cam. Tears at top left and bottom center. The whole O-Ring was pretty smooshed. My mistake to reuse it
Post by boileralum on Dec 22, 2015 13:51:59 GMT
Glad you were able to find it. And like you said, at least it is easy to work on
Post by dietcoke on Dec 25, 2015 3:45:24 GMT
Old filter had a minute bit of fine copper glitter, but I'm cautiously optimistic the new plate and filter will fix it for good, and I won't need a rebuild. Oil pressure has doubled from 25 psi cold start to just over 50. Will test warm pressure tomorrow when I can get a hold of a new crank bolt (if I can, anyway), but it should finally be good.
Post by dietcoke on Dec 25, 2015 9:28:44 GMT
Since the oiling system is fixed, got to work on mounting the accusump. Due to its physical size, didn't have a lot of mounting options but it just fits behind the drivers seat with these trick billet brackets. With it installed, finally ready to tackle the road course.
Post by zeitgeist on Dec 25, 2015 17:50:45 GMT
Good news on the improved oil pressure. Hopefully problem solved. With the Accusump was there room to mount it behind the passenger seat or too tight? I don't remember if you had yours corner weighted or what the balance was just thinking more weight on the passenger side and running the lines in the tunnel.
Post by dietcoke on Dec 26, 2015 3:04:03 GMT
It would have interfered with the battery. The driver's side is also a shorter line run to the oil port on the engine.
