Post by exo2015 on Dec 13, 2015 6:29:32 GMT
Good question haven't got to the wiring stage
Post by exo2015 on Dec 13, 2015 6:30:15 GMT
Have decided to put some graphics down the sides, spotted on another post
Post by exo2015 on Dec 13, 2015 6:32:00 GMT
Windscreen fitted, 4 washers to keep it away from the body work
Post by exo2015 on Dec 13, 2015 6:35:44 GMT
Interior basically finished, got to wire up the gages and starter button, had fun with the horn but after a few hours of no luck, Tom came to the rescue and fixed it in under a minute, thanks again Tom.
Post by exo2015 on Dec 13, 2015 6:38:08 GMT
Still not happy with the brakes, have bleed them twice and no bubbles left in the line, original calipers hard pedal but poor braking so on the hunt I go.
Post by exo2015 on Dec 13, 2015 6:46:43 GMT
Waiting on a connector from the UK which will allow me to install a new filler cap in the top of the tank, so I can fill the tank Had great fun trying to get the fuel filler to work have gone with the original filler for now will sort after compliance
Post by exo2015 on Dec 13, 2015 6:49:39 GMT
Post by exo2015 on Dec 13, 2015 6:54:48 GMT
List of jobs slowly reducing, speedo cable, exhaust, wheel alignment, then certifying, earliest date is the 22nd of January so not able to get on the road yet.
Post by adelaideexocet on Dec 13, 2015 8:10:30 GMT
Which connector have you got coming from the UK? I've just been playing with my fuel filler this arvo and its interesting to try and bend everything on the right angle and still allow me to fill a fuel tank!
I might use those decals as a template for mine if that is okay. Although mine will be in red!
Post by exo2015 on Dec 13, 2015 8:41:38 GMT
Post by gwnwar on Dec 13, 2015 20:01:19 GMT
Really like your color combo.. graphics set off the car.. For your brakes looks like the rotors need a surface cut to clean up.. Run the pads over a piece of flat sand paper to clean them.. Check all your caliper slide pin for being clean and lubed. Clean out the housing they go into for old grease. don't over lube. Readjust the screws in rear calipers with E brake off.. Are all bleed ports on upper side of calipers. See you like blue cars..
Post by dave on Dec 14, 2015 0:03:35 GMT
Liking the look of this one, have you any pictures of how you mounted the rear lights?
Thanks Dave
Post by exo2015 on Jan 15, 2016 6:20:13 GMT
Finally managed to get the brakes working faulty hose from brake booster
Post by exo2015 on Jan 15, 2016 6:23:35 GMT
Car all loaded up ready for wheel alignment and exhaust fitting, took some time to get it on due to how low the Excel is, thanks again Tom for your help
Post by exo2015 on Jan 15, 2016 6:26:51 GMT
