Post by exo2015 on Sept 18, 2015 10:22:25 GMT
Chassis all bolted up onto the suspension, after some minor modifications, thanks Tom great customer service, prompt response to a minor issue with the chassis bolts.
Post by adelaideexocet on Sept 19, 2015 13:21:56 GMT
Looks good. I'd also suggest putting some heat proof mat under the trans tunnel. The cat converters get hot and it will also help keep the passengers legs cool and the vinyl in place!
I might do some vinyl wrap myself or actual padded vinyl
Post by exo2015 on Sept 20, 2015 6:22:02 GMT
Coil overs installed BC Gold, will need to move the top hat hole slightly to give more clearance
Post by exo2015 on Sept 20, 2015 6:24:50 GMT
Radiator installed seems a bit low but bolts holes line up
Post by exo2015 on Sept 20, 2015 6:27:32 GMT
Transmission tunnel refitted with hole cut out for the gear leaver, tap is just holding the carbon wrap in place well I worked around it
Post by exo2015 on Sept 20, 2015 6:28:37 GMT
Steering wheel and ignition installed
Post by exo2015 on Sept 20, 2015 6:30:54 GMT
Maxim headers trial fitted, will polish them up once I have the car running
Post by exo2015 on Sept 20, 2015 6:32:35 GMT
Rear tail lights installed and wired up
Post by exo2015 on Sept 20, 2015 6:35:41 GMT
Brake lines connected from the rear of the car, fuel lines connect to the front of the car, and lines ready to connect to the tank. Trial fitted the seats but the brackets don't line up with the holes so need to have another look on another day
Post by gwnwar on Sept 20, 2015 19:58:19 GMT
Transmission look very high in the tunnel hole.. Check the on the drive shaft trans to diff.want it just off a straight line.. like a degree or two.. You might want to get the headers ceramic coated..will cut down on the heat.. Coming together nicely now.. like the insides..
Post by exo2015 on Sept 21, 2015 5:44:43 GMT
Thanks for the feedback
Post by exo2015 on Sept 21, 2015 5:45:45 GMT
Spent some time today fitting the dash cluster and new pedals, and trial fitted the bonnet happy with the colour scheme and the look
Post by exo2015 on Oct 14, 2015 7:45:12 GMT
Managed to fit the seats passengers side was a real challenge, raised the steering column up and fit into the car fine now
Post by exo2015 on Oct 14, 2015 7:47:54 GMT
Finished off the firewall and gear surround, blue sticking continued through from steering wheel, hand brake also installed
Post by exo2015 on Oct 14, 2015 7:50:54 GMT
Have also continued the carbon fibre wrap on the inside of the side panels
