Post by exo2015 on Oct 14, 2015 7:53:24 GMT
Fuel tank trial tested haven't decided where to put the fuel filler, and trial tested the tank cover, just got to finish off fuel lines to the tank when I decide the final location My son has just turned 16 and is allowed to start to learn to drive so stuck the L on the back in preparation, he confident that the car is going to be finished soon.
Post by kiwicanfly on Oct 14, 2015 9:12:13 GMT
If I had a son who had just turned 16 and was about to start to learn to drive I would suggest he stuck the L plate on something else as it would be a lot quicker. The joke down the pub is that the reason I am taking to long is that I am building a new car that will be old enough to be registered as vintage when it is complete Where are you by the way?
Post by OzExoNinja on Oct 14, 2015 10:10:33 GMT
Nice build mate! Can i ask what tires you have on it, they look pretty aggressive?
Post by exo2015 on Oct 15, 2015 2:39:01 GMT
If I had a son who had just turned 16 and was about to start to learn to drive I would suggest he stuck the L plate on something else as it would be a lot quicker. The joke down the pub is that the reason I am taking to long is that I am building a new car that will be old enough to be registered as vintage when it is complete Where are you by the way? I'm in Auckland not far from Tom's, yes I think my son is more confident than me
Post by exo2015 on Oct 15, 2015 2:41:02 GMT
Nice build mate! Can i ask what tires you have on it, they look pretty aggressive? Tires are Nitro nt01 semi slick, road legal 205 x 15 x 50 on 15 x 7 wheels
Post by exo2015 on Nov 14, 2015 23:16:27 GMT
Well have installed the wire loom, not tidied up yep but found all wires minus a couple, will deloom some more now that I have everything working
Post by exo2015 on Nov 14, 2015 23:17:29 GMT
Have also fitted the induction piping and pod filter lots of much in around but all secured, also installed a new over flow tank
Post by exo2015 on Nov 14, 2015 23:18:48 GMT
Engine fired up for the first time, had an interesting start had a split fuel line which sent fuel everywhere, but once replaced car going good, need to bleed the brakes and clutch then it time for a noisy trip round the block
Post by exo2015 on Nov 14, 2015 23:19:52 GMT
Painted the grill black to match the chassis
Post by exo2015 on Nov 14, 2015 23:20:46 GMT
Headlights and indicators installed and working, tidied the wiring loom up at the same time
Post by exo2015 on Nov 14, 2015 23:21:30 GMT
Aero catches finished and bonnet secure
Post by exo2015 on Nov 14, 2015 23:28:42 GMT
Fitted wing mirrors
Post by exo2015 on Nov 14, 2015 23:31:18 GMT
Well tried to bleed the clutch with no luck, master cylinder appears to be buggered so have ordered a new one
Post by exo2015 on Nov 14, 2015 23:35:57 GMT
Have decided to do a custom Centre console with gauges, buttons and a push start button, the wiring loom will now be hidden behind the console, which will also have side panels, gauges and buttons all illuminate blue when in use
Post by adelaideexocet on Nov 15, 2015 23:34:45 GMT
That centre panel looks sexy! How are you going to overcome the immobiliser with the push button start?
