Post by jon on Apr 30, 2016 3:38:36 GMT
Added cable supports for the wing. Doesn't budge now. I used roll bar clamps on the frame side so it would be easily removable.
Post by jon on May 22, 2016 18:07:25 GMT
A picture with some Miatas
Post by mawdo81 on May 31, 2016 17:12:59 GMT
Makes them look wet behind the ears!
Post by jsmith on Jun 1, 2016 20:54:32 GMT
Nice! Are those JNC wheels?
Post by jon on Jun 2, 2016 3:41:17 GMT
Nice! Are those JNC wheels? Yep. Jnc 003. Same as the traklites, but cheaper.
Post by jon on Aug 20, 2016 23:15:41 GMT
New track in town.
Post by SeanW on Nov 13, 2016 22:06:08 GMT
Do it Jon! I built the larger 1000mm X-Carve a couple months back and am absolutely loving it after upgrading the spindle to the Dewalt 611. Regarding the rear fender mounts, I have a one piece rear mount in the works now that I should be able to start testing this spring. Hopefully will test out to be more sturdy and easier to install. Any update on the updated rear fender mounts?
Post by jon on Feb 20, 2017 3:57:08 GMT
Post by jon on Feb 25, 2017 20:31:51 GMT
A few small updates: 1. Added a small battery: 2. Installed Megasquirt PNP2 Had to weld a new O2 bung onto the exhaust for the wideband: Finally, I 3d printed a simple adapter for the cone filter and intake temp sensor. Plan on redoing this to make it look better later. The megasquirt is awesome. There were a few problems with the basemap, but once those were resolved it was all good. Ran autotune a bit and adjusted the cranking pulse. Also increased the accel enrichment. Running very well now. My butt dyno tells me I picked up a few HP, too!
Post by n0p0wer on Jul 9, 2020 18:08:55 GMT
Hey Jon, not sure if you're still getting alerts from the forum but Zeitgeist sent me your way for tips/tricks/recommendations on registering an Exocet in Michigan. Let me know if you get this. Thanks!
