Post by lhintze on Sept 12, 2015 14:18:47 GMT
Very nice so far! What are the specs on your wheels/tires? Also, whats the silver box before the air filter?
Post by jon on Sept 12, 2015 16:27:32 GMT
Jnc 003 wheels. Same as the holeshots. Kumho v720 tires.
The box is the MAF sensor! Hope to delete that eventually with a different ECU.
Post by jon on Sept 16, 2015 1:20:19 GMT
I am trying to discourage passengers from putting their full weight on the floor panels
Post by jon on Sept 16, 2015 2:45:41 GMT
this is all that stands in the way of cranking
Post by jon on Sept 19, 2015 23:52:32 GMT
It lives!!
Post by jon on Sept 19, 2015 23:54:15 GMT
Question: I got my car running but had a hard time getting the fuel pump to turn on. We traced the problem back to the MAF air meter (1990 donor). There is apparently a switch in there that needs to be closed to apply power to the fuel pump. We confirmed the switch is open and the source of my trouble.
I was able to get fuel pump on by jumping two pins in the diagnostic port. Then it ran.
Is this switch the roll over sensor? How do I reset it?
Thanks!!
Post by snowbird1 on Sept 20, 2015 6:34:40 GMT
Question: I got my car running but had a hard time getting the fuel pump to turn on. We traced the problem back to the MAF air meter (1990 donor). There is apparently a switch in there that needs to be closed to apply power to the fuel pump. We confirmed the switch is open and the source of my trouble. I was able to get fuel pump on by jumping two pins in the diagnostic port. Then it ran. Is this switch the roll over sensor? How do I reset it? Thanks!! The switch in the AFM ensures the pump only runs if the engine is turning, it should close as soon as the flap moves, you should be able to hear it click when you manually move it. The fuel pump relay (oddly called the 'circuit opening relay' in some circuit diagrams) also gets an 'on' signal from the starter, if the AFM switch is not working it will fire up when cranking but die when the key is released.
Post by jon on Sept 20, 2015 12:11:29 GMT
Thanks! Maybe the starter closing is not turning on the fuel pump. That may be the piece of this puzzle I am missing.
Post by jon on Sept 20, 2015 12:37:14 GMT
Thanks to some inout I think I just had an "ah ha" moment: yesterday, after starting, we discovered that I had a small vac leak. I bet that leak was preventing it from closing during slow cranking. I bet it will work fine on its own now.
This all makes more sense to me now: normally the fuel lines hold fuel pressure so it starts without delay when you crank. In this case, I never got adequate vac to turn it on.
Post by jon on Oct 12, 2015 1:19:32 GMT
Been a while since update. I have been working on getting the harness in permanently. I 3d printed a lot of small grommets, clips, and mounts. Put some big holes in the firewall to route the harness. I plan on making some sort of carbon dash that is a few inches wide that will cover up the harness from the interior view. Should be ready for a drive soon!
Post by steadfast on Oct 12, 2015 3:46:55 GMT
Looks great, love the 3D printed items!
Post by zeitgeist on Oct 12, 2015 3:52:52 GMT
Looking real good Jon. I would love to check it out in person if you wouldn't mind. Glad to see it come together.
Post by jon on Oct 12, 2015 4:38:44 GMT
Looking real good Jon. I would love to check it out in person if you wouldn't mind. Glad to see it come together. Are you in the Detroit area during the weekends? I think i saw you were moving...Usually the best time for me. Would be fun to meet up!
Post by einy on Oct 12, 2015 12:33:20 GMT
Looking great, Jon!
Post by zeitgeist on Oct 12, 2015 14:50:31 GMT
Looking real good Jon. I would love to check it out in person if you wouldn't mind. Glad to see it come together. Are you in the Detroit area during the weekends? I think i saw you were moving...Usually the best time for me. Would be fun to meet up! I'm not in MI for weekends off just weekends working but I can re-arrange my schedule to check out the build if weekends work best. This weekend I'm away but next weekend can work if you are available. PM or email me.
