Post by jon on Aug 20, 2015 1:40:26 GMT
Corbeau FX1 Pro. I like em!
Post by jon on Aug 20, 2015 11:31:38 GMT
Had to file the upper control arm. Now have more clearance.
Post by steadfast on Aug 20, 2015 14:15:36 GMT
Do you have the tophat spacers? This would set the coilover in more of a center position.
Post by jon on Aug 20, 2015 19:10:20 GMT
Yes, I do have the spacers.
These are replacement control arms on the top. Maybe they are a few mm wider.
Post by jon on Aug 22, 2015 15:08:01 GMT
Got pedals and steering installed. Had to lengthen the steering shaft by half an inch using an air chisel and torch.
Post by einy on Aug 25, 2015 13:16:37 GMT
Jon - got my exhaust fitted this weekend. Not sure if you are there yet, but found out (with test pipe instead of the cat installed) that once all was 'snugged up', it only sits about 1" below the bottom of the chassis / frame. Again, this is with the test pipe installed. Not sure how this compares to what you'll find with the cat, but hoping it will be similar. No grounding out on mine on short test drive through the neighborhood, despite having a rather severe uni-curb at the end of my driveway.
John
Post by jon on Aug 25, 2015 14:45:00 GMT
Thanks. I will put my full exhaust on once I am done running brake and fuel lines.
Based on what I can see, 1" sounds about right for me too. I don't think my cat will sit any lower.
Post by beav on Aug 26, 2015 15:46:38 GMT
What Driven wheel is that please?
Post by jon on Aug 26, 2015 22:53:19 GMT
It's the one on exomotive's website without and dish; flat wheel.
Post by jon on Aug 27, 2015 1:48:46 GMT
Post by jon on Aug 27, 2015 2:05:05 GMT
Also, my bodywork was shipped. Things are moving fast!
Post by jon on Aug 29, 2015 14:44:59 GMT
This was scary driving home!
Post by einy on Aug 29, 2015 20:39:55 GMT
Jon,
Can you provide details on your center mirror and its mount please?
also, tape up your valve cover cam belt bulge with at least four layers before you first try to see how the front bodywork looks. Trust me !!!!
John
Post by boileralum on Aug 30, 2015 15:00:37 GMT
Hey einy - do you think there will be a fitment issue with hood and the VVT actuator valve on the 01-05 engines?
Post by jon on Aug 30, 2015 15:35:54 GMT
