Post by mawdo81 on Aug 9, 2015 16:09:22 GMT
Gas/blow torch ;-) heat it up and brute force
Post by jon on Aug 9, 2015 16:17:03 GMT
I'll wait until the exhaust is all on there before I start bending!
Post by tacan on Aug 9, 2015 18:23:32 GMT
That picture makes me concerned about my dreams of closing off the trans tunnel for a flat bottom...
Post by mawdo81 on Aug 9, 2015 18:24:23 GMT
You'd be boxing in a lot of heat...
Post by jon on Aug 10, 2015 15:42:00 GMT
My APR wing was too awesome looking to not install it! Might get in the way... but I just want to look at it Right now I have it set so that the leading edge of the middle section is level with the horizon. Curious what angle of attack others have it set to?
Post by ImprobableConstruct on Aug 10, 2015 19:42:45 GMT
I have the COT wing but I did the same thing. It didn't get in the way until I went to install the rear body work.
Post by greg on Aug 11, 2015 11:39:18 GMT
Mine is set for completely flat for street driving. For auto-X it'll be full tilt.
Post by jon on Aug 11, 2015 13:32:06 GMT
Mine is set for completely flat for street driving. For auto-X it'll be full tilt. Thanks! I'll keep mine level for the time being. Some other questions: Did you put any loctite on the bolts that thread into the wing? I know they will be fine, and maybe an irrational fear, but it makes me nervous with relatively small bolts holding it together.
Post by greg on Aug 11, 2015 14:09:58 GMT
No but I did put a light coating of never seize.
Post by jon on Aug 13, 2015 14:54:51 GMT
Just like SteadFast, I think I am going to get a Speedhut gauge. My gauge cluster was tampered with by the previous owner. They damaged the odometer and the speed doesn't read exactly right. I am trying to figure out about the other gauges. I may try to reuuse the movements for fuel, oil, and temp. Otherwise, maybe make some custom Arduino LCD with that info displayed.
Post by mawdo81 on Aug 13, 2015 15:00:23 GMT
I know GPS coverage is better these days, but it does mean you won't have any speed reading in tunnels etc...
Post by jon on Aug 13, 2015 16:36:47 GMT
Indeed, but if I know RPM for a given speed and gear, I can have a good enough idea.
Post by jon on Aug 19, 2015 13:55:45 GMT
I put the front coil overs on last night with exomotive spacers. Clearance is really thin between shock and upper a arm... is this a problem? Granted, camber is not adjusted at all, so that may help (or hurt).
Post by jon on Aug 19, 2015 19:00:42 GMT
Got some seats too!
Post by einy on Aug 20, 2015 0:33:13 GMT
What model are the seats?
