Post by vcpwayne on Apr 24, 2015 23:08:06 GMT
Tail lights are on and all the wiring is complete.
Post by ImprobableConstruct on Apr 24, 2015 23:21:45 GMT
Looks angry. Have you you started the registration process yet? It's super easy in Alabama and I have the info if you need it.
Post by vcpwayne on May 1, 2015 1:50:57 GMT
Haven't started registration yet.
Post by vcpwayne on May 3, 2015 16:48:01 GMT
Post by vcpwayne on May 4, 2015 21:03:26 GMT
I wasn't happy with how much the dash vibrated so I made mount from the upper column mount to the dash surround. Solid as a rock now.
Post by ashneyder on Jun 7, 2016 18:52:47 GMT
How did this bond hold up? I am planning to do the same, but trying to figure out if I need to lay the fiberglass mesh on top of it, or if just using the adhesive is sufficient. Here they are bonded in.
Post by vcpwayne on Jun 7, 2016 19:07:15 GMT
Adhesive that I used is holding great, it is SEM 39337. It has had a hundred street miles and a couple track days.
Post by ashneyder on Jun 7, 2016 19:38:52 GMT
Thanks Wayne. I already have the adhesive above. The discussion we are having if we need to add fiberglass mesh on top of the adhesive, or just the adhesive should be more than enough.
Post by einy on Jun 8, 2016 11:07:49 GMT
Good timing on this discussion, as I'm about to jump into fender mounting myself, and prefer what you did, Wayne, over any other method I have seen!!
Post by ashneyder on Jun 8, 2016 14:25:26 GMT
Fenders is the only thing I have left. Planning to spend the whole weekend working on them. One thing to watch out for: the SEM adhesive requires a special dispenser gun, which is ~$100. By a lucky coincidence, I have ran into a guy on Monday, who happened to have one to let me borrow it.
Post by gwnwar on Jun 8, 2016 18:43:52 GMT
For piece of mind after the SEM adhesive drys a couple of 4" wide pieces of glass won't hurt.. It would make me feel better doing it.. Better safe then sorry..
