Post by steadfast on Apr 4, 2015 4:58:18 GMT
damn it, I wish I knew about those base studs. You sir just set a new standard!
Post by einy on Apr 5, 2015 14:35:45 GMT
Does the 1" stud length seem about right, or too long / too short? I see MMC has a lot of choices, and even offers these in 316 stainless !
Post by jmills on Apr 6, 2015 2:49:37 GMT
What did you use to bond them?
Post by vcpwayne on Apr 6, 2015 13:25:16 GMT
1`" seems perfect I set the stud plates in then bond them in with SEM 39337 Door Skin adhesive. Rough up the fiberglass first for the best bond.
Post by vcpwayne on Apr 9, 2015 21:21:30 GMT
OK, didn't like the exposed Dzus fastener nose mounts so I came up with this. The nose is pointed so I made brackets to bayonet the nose up/down and side to side. I made a fence to hold the rear of the hood and to block the hot engine air from the cockpit and holding down the hood with AeroCatches. If I did another, I'd use QuickLatches instead. Upper hood Side support Lower support
Post by vcpwayne on Apr 9, 2015 21:54:26 GMT
Made 2" spacers for the 1.8L tank.
Post by vcpwayne on Apr 14, 2015 16:57:46 GMT
Post by vcpwayne on Apr 15, 2015 16:39:44 GMT
I made a cold air intake.
Post by nomdenom on Apr 15, 2015 17:52:07 GMT
nice build !
is it an optical illusion or is the tank mounted lower than on the uk exocets ?
Post by einy on Apr 15, 2015 23:23:00 GMT
I really like how the fuel filler looks with the tail bodywork installed. Very tidy!
Post by jmills on Apr 16, 2015 2:18:15 GMT
What kind of fuel filler is that? Looks great, fitting with the rest of the build!
Post by jwagner on Apr 16, 2015 3:49:45 GMT
Pics are really useful - nice job and thanks.
Post by vcpwayne on Apr 16, 2015 16:45:23 GMT
Spent a few hours on the dyno this morning until this hose let go. It is the one from the rear of the motor to the heat exchanger on the oil filter. Making 240 RWHP at 12 psi and 21°
Post by greg on Apr 16, 2015 16:53:27 GMT
Pump gas? No meth?
Post by vcpwayne on Apr 16, 2015 19:40:30 GMT
Went for a short drive, soooooooo fun!
