Post by hockey930 on Apr 30, 2018 18:48:57 GMT
I had a problem with the ebay aluminum radiator and the flyin miata silicone throttle body hose running into each other. I cut down both the slicone hose and the radiator water neck to make the fit better. They still touch but I am calling it good enough. I was able to modify a pair of wire crimpers into a bead roller to put a small beat back on the radiator inlet. I decided to go with the hawley reroute kit. I has to cut down both sides of the hose it came with and was able to pair it to Dayco hose 71642. The dayco hose couldn't fit better, not only did it drop down the inlet about 8 inches but it also pointed in the direction I needed it.
