Post by kiwiev on May 10, 2014 11:34:10 GMT
hi everyone new here have just received kit from Southern Automotive out of Perth power car with HPEVS AC-35X2 AC motor and 160 amp/hour batteries for 200km range wondering if anyone else has gone electric not sure how to post photos but below is a link with photos so far. any comments would be much appreciated. cheers www.dropbox.com/sh/mnceynkm4vwengf/AABshPs7YPfv8uR0ru9ergNSa
Post by kiwiev on May 11, 2014 1:36:29 GMT
would anyone have photos of rear bonnet latches also the height of centre of steering boss to floor as im not using focus doner. thanks
Post by andybaird on May 11, 2014 7:15:10 GMT
Hi Some photos of the catches I have used on my sonic. Andy
Post by kiwiev on May 11, 2014 21:56:11 GMT
thanks Andy so latches are behind roll dar and the hooks are at the back of the car? im trying to get everything welded on chasis before i get it powder coated.
also what size tires are you running?
Post by redbeard on Jun 24, 2014 1:12:41 GMT
hi everyone new here have just received kit from Southern Automotive out of Perth Hi Kiwiev Great to see a Sonic in Aus. I am in Perth and interested in one, but surprised to see how different the Aus chassis looks compared to original MEV unit- Heaps more members and diagonals- Perhaps the tubes are thinner though- do you know what the chassis you have weighs? Your EV ideas look good, what sort of performance are you targeting?
Post by kiwiev on Aug 14, 2014 11:22:51 GMT
hi redbeard yes chassis is beefy my weighed about 105KG performance is conservitive at 0-100 km 3.3 seconds top speed 200km and range 200km total weight 600 kg have got chassis back from powder coater and have fitted out batteries check dropbox link below www.dropbox.com/sh/mnceynkm4vwengf/AABBRwXYWIjH53WOG6n-xNBuacheck you tube video
Post by kiwiev on Oct 5, 2014 9:54:20 GMT
hi guys here is another quick video of motor fire up
its revving from 0-8000 rpm in .1 of a second should be interesting to say the least
Post by kiwiev on Oct 21, 2014 10:03:11 GMT
finally got 12 volt wiring done phew. Moved main electric contacts to a electrical box and put in a shut load to use to run fuel battery gauge. plumbed in brake lines and mounted master cylinders. Next job is to drill and tap grease nipples into suspension arms, then mount up with out body panels to do a few shake down runs.
Post by kiwiev on Oct 21, 2014 10:10:37 GMT
Post by kiwiev on Nov 5, 2014 5:37:29 GMT
Post by cooldad on Nov 11, 2014 9:31:09 GMT
What minimum castor did you get.
Post by bluecob99 on Nov 11, 2014 13:31:51 GMT
Hi Kiwiev, I live in Perth just finished the Trike R1, interesting bit of kit there, nice to see something different on the roads! Who's building it for you?
Post by kiwiev on Nov 13, 2014 22:41:11 GMT
What minimum castor did you get. [ Hopefully 8deg pos will have to wait for wheel alignment to see what I can get?
Post by kiwiev on Nov 13, 2014 23:04:04 GMT
Hi Kiwiev, I live in Perth just finished the Trike R1, interesting bit of kit there, nice to see something different on the roads! Who's building it for you? Hi blue cob love to see photo of trike I live south of canberra I'm building her myself hopefully have a shake down run in 3-4 weeks will you tube run with out body on just in case I have to get to things Should be interesting has 280 ft pounds of torque at 1 rpm and 148 kW Cheers conrad
Post by bluecob99 on Nov 14, 2014 8:01:57 GMT
Hi Conrad, Sounds quick mate, what's the handling like on that kit? sure will have to be good to handle the power!! How long does that thing take to charge and how long befour runs dry?? Would be interesting to know! Regards Will
