Post by r1ckbuilder on Feb 14, 2015 8:30:50 GMT
I think I've been fortunate with the silicon hoses (for the price, I should be!) but that was mainly thanks to reading your thread and hearing about the issues you were having. Once again I visited many forums on the vagaries of silicon hoses and amongst the bad press (apart from looking pretty) it made a big point of cleaning all the contact surfaces, so I cleaned metal joiners and the inside of the pipes within an inch of their life.
And what do you know? When I had the tunnel out the other day, at the engine end there was a minor weep that had left a small puddle on the floor sheet. 'Have silicon, be prepared to top up often', would that be the saying?
Post by Deleted on Feb 14, 2015 22:36:31 GMT
Not sure its the case for any other people, but from my experience I won't use Silicone again. For me, its a poser pipe, not reliable enough. If they were that good, they would be factory fitted.
Sent from my Nexus 5 using proboards
Post by r1ckbuilder on Feb 15, 2015 9:56:58 GMT
'Poser Pipe'?
I have no idea what you mean? LOL, I was tempted by the gold hoses but at £60 a meter I passed.
In all seriousness, I went with the silicon as it seemed everyone else was. I did find the wire reinforced stuff simplified the route of the pipe and removed the 'kink' worry. I didn't look to see if there was something similar in rubber.
Post by r1ckbuilder on Feb 28, 2015 16:08:58 GMT
Yesterday the sun was out, the roads were dry, it had been a long week so I took the Tr1ke out for a spin,
Post by andy7b on Mar 10, 2015 22:29:42 GMT
Ah yes so you have:-) looks and sounds great to me, the whole build looks a really neat and clean job. So are you please with your creation :-) I can only imagine yes is the answer, I find I just look for any recuse to go for a drive even just to the shop for milk that we don't need:-) Andy
Post by r1ckbuilder on Mar 22, 2015 18:09:37 GMT
Hi Andy,
I am pleased with the build, even if the odd issue has come up, but that's all part of the fun. Even more chuffed with the TR1ke as a machine, itself. it's proper fun and scary all at the same time.
Milk run is a good idea but thanks to your suggestion, I'm now considering the weekly shop in it. With the storage capabilities of the Tr1ke it would take me 10-15 trips!
Cheers, Richard.
Post by r1ckbuilder on Mar 22, 2015 18:28:22 GMT
Evening,
So just the same as lakestr1ke in his 'help' thread my engine stopped near the end of a 20 mile trip. I was coming into my village and was changing down and put my foot on the clutch and...... nothing, the engine just stopped. After about 5 minutes, it decided to start again and I nursed it the rest of the way home. I did a bit of 'Googling' on the subject and similar issues were put down to the throttle position sensor (TPS). I read the manual and found how to test the TPS and all seemed fine. When I put the TR1ke together I never took the throttle bodies apart so decided to remove them to make sure everything was clean and free moving. Please note the number on the sensor - On the left is the TPS and on the far right is the secondary TPS I believe. I'd read the TPS had been modified so made the assumption that because both has the same number, mine probably hadn't. Anyhow, a new TPS is £120, so when I saw an entire throttle body on Ebay for £100, I gambled and bought it. Below is the new throttle bodies on the engine. note the number on the TPS again -
I making a bit of a leap of faith here but I'm hoping the number change means the replacement Throttle bodies has the modified TPS. What you can't see is the mismatched screw holding the other side of the sensor in. I'm taking this as another indication someone's had the sensor out and dropped the screw (we've all been there).
Roads were dry today so I took her out for a bit of a trip again to test things out and I'm happy to report no issues at all. In fact it seems a bit faster!
