Post by sandancer73 on Sept 15, 2014 19:25:41 GMT
I've now figured out why it won't fire up. I've replaced the fuel pump but found out its a universal item! Now when the pump primes I can see the feed pipe rise under pressure, but once stopped it soon falls down. I'm sure the universal pump is not sealing correctly and the petrol is return back into the tank and depressurising the fuel line (hence no fuel in the pots). New pump sender unit is going to be ordered this week to hopefully resolve this issue. Wired the fan & horn tonight, getting more confident in the wiring department. Pics to follow.
Post by Paul (madeye) on Sept 15, 2014 19:59:02 GMT
Post by sandancer73 on Sept 15, 2014 21:14:12 GMT
What are they required for?
Post by Paul (madeye) on Sept 16, 2014 6:07:28 GMT
you could try it inline to hold the fuel pressure.
Post by sandancer73 on Sept 16, 2014 12:01:11 GMT
Paul,
To keep it simple, I'm gonna pursue getting the right pump set-up. Thanks for the offer.
Post by sandancer73 on Oct 2, 2014 10:02:09 GMT
Well yesterday seen another milestone accomplished. I finally managed to fire up the engine after a few weeks of head scratching ( including 3 fuel pumps)! A big thank you to the guys at Omex for cross checking that all was working from an electrical aspect and Luke at RTR for identifying the simple (but not obvious to me) exchange of the fuel pipes. I can clarify for future builders, the fuel flow connects to the pipe on the rail (via a filter) and the return to the pressure regulator end of the rail (via a diaphragm) to the tank. I will post some pictures soon.
Post by sandancer73 on Oct 8, 2014 17:08:02 GMT
Picked up my exhaust, headlights, sidelights and tank cover from RTR today. That's a busy weekend for me.
Post by sandancer73 on Nov 28, 2014 20:30:15 GMT
Off to RTR in the morning to drop off the Rocket ready for IVA.
Post by richo on Nov 28, 2014 20:43:50 GMT
Hope your IVA goes well. Do you have any finished pics?
Post by juddyjuddster on Nov 28, 2014 21:40:30 GMT
Well done its in the bag, not long now!
Post by sandancer73 on Nov 29, 2014 17:24:06 GMT
Post by pocketrocket on Dec 1, 2014 1:37:26 GMT
What are the lights you're using? (all of them)
Post by richo on Dec 1, 2014 8:53:04 GMT
Looks realy good. Well done.
Post by sandancer73 on Dec 1, 2014 12:29:40 GMT
What are the lights you're using? (all of them) PR, Front are RTR supply Photon headlights and LED side, Rear are CBS supply LED combined side, brake and indicator, combined fog and reverse, LED Focus number plate light from Ebay. I wanted a minimalistic look. Thanks for the comments. Applogies for the non comprehensive build diary, my main focus was on the build however I will gladly provide advise / help to anyone with any questions.
Post by sandancer73 on Mar 22, 2015 20:45:59 GMT
IVA booked for Friday, many thanks to Mark at Automotive Solutions for finishing off the work in readiness. Fingers crossed.
