Post by greg on Oct 28, 2014 11:58:36 GMT
That's a great idea! I was thinking of some kind of spray on insulation for mine.
Post by miatagr on Oct 29, 2014 0:56:27 GMT
Saferacer sells a kit for spec miatas.... I've put in the floor one and will do the trans tunnel when I get time.. floor one seems to work fine but may not be pretty enough ...
Post by steadfast on Nov 3, 2014 4:17:57 GMT
Post by clintavo on Nov 3, 2014 6:16:43 GMT
Seems like a decent material to rest your arm on/leg against (is it for the center tunnel?). I would install it so it can be removed fairly easily once it wears out.
Post by gwnwar on Nov 3, 2014 6:50:24 GMT
That will be a nice finish touch for the tunnel and rear bulkhead..I would cut to size then have a shop sew a beading around the edge. Maybe sew it on to some thin insulated blanket.. Then held on with a couple of black snaps..
Post by steadfast on Nov 3, 2014 16:41:07 GMT
That will be a nice finish touch for the tunnel and rear bulkhead..I would cut to size then have a shop sew a beading around the edge. Maybe sew it on to some thin insulated blanket.. Then held on with a couple of black snaps.. You read my mind. I was planning on doing that exact thing.
Post by steadfast on Nov 6, 2014 19:28:58 GMT
Post by clintavo on Nov 6, 2014 19:45:15 GMT
That is fancy! So are you officially road legal?
Post by steadfast on Nov 6, 2014 19:54:04 GMT
Not road legal yet, one more step. That is the BAR (Bureau of Automotive Repair). This is the most important part. I need my bodywork to complete this part. Hoping it ships this week.
Post by steadfast on Nov 6, 2014 19:57:22 GMT
Post by clintavo on Nov 6, 2014 20:09:41 GMT
That's one thing I am worried about. No doubt mine will have a CEL, since none of the emissions stuff exists, including the first cat.
My plan is to disable the light. I will hide the OBD2 port just in case.
montgom
Love Exocet
Post by montgom on Nov 6, 2014 20:45:00 GMT
That is fancy! So are you officially road legal? More pictures!!!! The car is gorgeous!
Post by steadfast on Nov 6, 2014 21:52:34 GMT
That's one thing I am worried about. No doubt mine will have a CEL, since none of the emissions stuff exists, including the first cat. My plan is to disable the light. I will hide the OBD2 port just in case. Yeah, I'm planning on the same thing. They don't have any need to use the OBDII port. I will just ziptie it out of the way and pull the light. I find it funny that the evap crap is causing a random misfire code (P0300). The car runs perfect. I am putting on a LC-1 this weekend, just to make sure it isn't causing me to run rich.
Post by JIDiesel on Nov 7, 2014 2:23:14 GMT
That's one thing I am worried about. No doubt mine will have a CEL, since none of the emissions stuff exists, including the first cat. My plan is to disable the light. I will hide the OBD2 port just in case. What port??? the harness never had one.
Post by steadfast on Nov 7, 2014 2:30:10 GMT
Hmmmm, there should be one. Once you remove the dash from the donor, on the back side is another harness which includes the OBDII port.
