Post by bluecob99 on Nov 17, 2013 0:58:28 GMT
Thanks Slugshot, Yes your right the picture is taken from the top of bottle, it has a sealed screw on top, if I connect to the thermostat section what would you do to the other pipe which serves carbs etc, could I Tee into the feed which will feed the bottle (of the thermostat housing) what do you think?? My radiator does not have separate connection as its a R6 rad to connect to. Thanks for the information of the cables mate. Cheers, Will
Post by bluecob99 on Nov 17, 2013 4:58:32 GMT
Hi again, yep there is a small return on radiator it was covered???
Post by slugshot on Nov 17, 2013 9:51:41 GMT
Hi Will,
Post pic's of your rad and overflow tank showing clearly all the outlets, and don't zoom in too close.
Cheers, Kevin
Post by bluecob99 on Nov 19, 2013 3:37:22 GMT
Ok Slugshot, will do, regards to gear change mech, the rod from the original sprocket you guys have for gear change, is this your own fabrication or can you purchase this and maybe where?? Cheers Will
Post by slugshot on Nov 19, 2013 23:17:02 GMT
regards to gear change mech, the rod from the original sprocket you guys have for gear change. Cheers Will Is it me or does that not make any sense...the rod from the original sprocket... If you mean do we buy or make our own gear change levers and links then I think you'll find by looking through all our threads that we make as much as we can and maybe modify the yamaha parts as well. Cheers Kevin
Post by bluecob99 on Nov 20, 2013 7:49:55 GMT
On the gear change to the engine, I've notice a long linkage bar?? does that make anymore sense, (made your self's or a purchased part?) Cheers, Will
Post by slugshot on Nov 20, 2013 10:51:43 GMT
My gear change cable connects to the original r1 splined fitting that goes on the gear selector shaft. The cable is a push-pull type that does away with the need for the rod.
Post by bluecob99 on Nov 20, 2013 11:50:56 GMT
Thanks mate, where can I purchase that from? Cheers, Will
Post by Deleted on Nov 21, 2013 12:14:14 GMT
I have one :-) 1.5mtrs long, i'm sure you can source one locally, but if not, should I price up sending this one over?
Post by Deleted on Nov 21, 2013 12:22:05 GMT
Giving serious consideration to sending this cable I check the Postal Service restrictions..... Most are common I suppose, and some are fairly strange (Soap etc)
However pay close attention towards the bottom of this list, in Bold for your amusement...
Prohibited products are not permitted in the mail under any circumstances.
Live animals; animal products Live animals Vegetable products Live trees and other plants; bulbs, roots and the like; cut flowers and ornamental foliage Edible vegetables and certain roots and tubers Oil seeds and oleaginous fruits; miscellaneous grains, seeds and fruit; industrial or medicinal plants; straw and fodder Mineral products Mineral fuels, mineral oils and products of their distillation; bituminous substances; mineral waxes Products of the chemical or allied industries Inorganic chemicals; organic or inorganic compounds of precious metals, of rare-earth metals, of radioactive elements or of isotopes Tanning or dyeing extracts; tannins and their derivatives; dyes, pigments and other colouring matter; paints and varnishes; putty and other mastics; inks Soap, organic surface-active agents, washing preparations, lubricating preparations, artificial waxes, prepared waxes; polishing or scouring preparations, candles and similar articles, modelling pastes, "dental waxes" and dental preparations with a basis of plaster Explosives; pyrotechnic products; matches; pyrophoric alloys; certain combustible preparations Miscellaneous chemical products Raw hides and skins, leather, furskins and articles thereof; saddlery and harness; travel goods, handbags and similar containers; articles of animal gut (other than silk-worm gut) Articles of leather; saddlery and harness; travel goods, handbags and similar containers; articles of animal gut (other than silk-worm gut) Pulp of wood or of other fibrous cellulose material; waste and scrap of paper or paperboard; paper and paperboard and articles thereof Paper and paperboard; articles of paper pulp, of paper or of paperboard Printed books, newspapers, pictures and other products of the printing industry; manuscripts, typescripts and plans Articles of stone, plaster, cement, asbestos, mica or similar materials; ceramic products; glass and glassware Ceramic products Machinery and mechanical appliances; electrical equipment; parts thereof; sound recorders and reproducers, television image and sound recorders and reproducers, and parts and accessories of such articles Nuclear reactors, boilers, machinery and mechanical appliances; parts thereof Optical, photographic, cinematographic, measuring, checking, precision, medical or surgical instruments and apparatus; clocks and watches; musical instruments; parts and accessories thereof Optical, photographic, cinematographic, measuring, checking, precision, medical or surgical instruments and apparatus; parts and accessories thereof Arms and ammunition; parts and accessories thereof Miscellaneous manufactured articles
God damn it, how will I get this Reactor to you now?
Post by bluecob99 on Nov 21, 2013 23:48:45 GMT
He he! nice one, looks like I may have to order from North Korea!! Thanks for the offer mate, I'll see if that would be long enough, if not where's a good place to purchase, just that Oz is not a big Kit car fan and bits like this are hard to come by, I'm a bit stuck for parts hence the questions lads? It's turning out to be a tough project with no parts at hand, and one thing and another! Still should be worth it. Cheers, William
Post by slugshot on Nov 22, 2013 0:51:11 GMT
Hi Will, As for cables I use a Venhill throttle cable with an inner liner for a smooth light feel, with these cables there's no need to add extra springs or a closing cable. They can make one to your length or as I did, buy the cable repair kit that comes too long so it can be cut to length, the kit also comes with an assortment of end fittings. My clutch cable is from CABLE TEC it is their 5mm light weight gearchange cable with 50mm of inner cable movement and uses clevis fittings at both ends. They do set lengths or can make one to your size.
Post by bluecob99 on Nov 22, 2013 12:06:44 GMT
Ordered them Slugshot, Many thanks. Will.
Post by bluecob99 on Nov 22, 2013 13:04:29 GMT
Forgot to ask, any of you guys got a pic of your set up to the gear change with cable (not click tronic) will help mooooooose fully! Cheers Will
Post by slugshot on Nov 22, 2013 16:34:52 GMT
Hi Will,
Take a look on my build thread, iv'e just added a clip from page 18 on my build thread it shows quite clearly the gear change setup and also the clutch cable setup.
There will also be pic's on the other build threads that you might find a better idea but you will have to look yourself.
