Shaun.. Are you sure that is the spring rates?? 9kg/mm= 504lbs..6kg/mm= 336lbs. Those are really stiff they are about 3 times more then an OEM MX5 spring.. You are going to have a very hard 2x4 up the butt ride.. Don't forget you have dropped 1/3 of the weight of the MX5.. I would go 200lbs less in front and 100 lbs less on rear springs.. see if you can exchange the one you have..
FYI..
Average MX5 Front 165lbs.
Rear 100lbs.
kg/mm to lbs/in
16 = 896
15 = 840
14 = 784
13 = 728
12 = 672
11 = 616
10 = 560
9.0 = 504
8.5 = 476
8.0 = 448
7.5 = 420
7.0 = 392
6.5 = 364
6.0 = 336
5.5 = 308
5.0 = 280
4.5 = 252
4.0 = 224
3.0 = 168
2.0 = 112
Manufacturer & Type Year Front Rear Linear/
Progressive R/F Ratio Optional
Rates? Comments
Mazda OEM 1990 164.17 96.94 Linear 59.0% No Red Dot Front, Blue Dot Rear
Mazda - Manual Trans 1991 164.17 96.94 Linear 59.0% No Red Dot Front, Blue Dot Rear
Mazda - Auto Trans 1991 153.52 93.53 Linear 60.9% No White Dot Front, Orange Dot Rear
Mazda - Manual Trans 1992 164.17 96.94 Linear 59.0% No Red Dot Front, Blue Dot Rear
Mazda - Auto Trans 1992 153.52 93.53 Linear 60.9% No White Dot Front, Orange Dot Rear
Mazda - Manual Trans 1993 164.17 96.94 Linear 59.0% No Red Dot Front, Yellow Dot Rear
Mazda - Auto Trans 1993 153.52 93.53 Linear 60.9% No White Dot Front, Green Dot Rear
Mazda - Manual Trans 1994 153.52 96.94 Linear 63.1% No White Dot Front, Yellow Dot Rear
Mazda - Auto Trans 1994 153.52 93.53 Linear 60.9% No Blue2 Dot Front, Green Dot Rear
Mazda OEM 'R Packag 1997 153 105 Linear 68.6% No
Mazda OEM Stock 1999 162 118 Linear 72.8% No
Mazda OEM Sport 1999 168 130 Linear 77.4% No
Apex* 89-'97 275 175 Linear 63.6% No *I've seen conflicting rates for Apex springs.
Most vendors won't tell you what they are.
Bilstein PSS-9 Coilover 1999+ 342 342 Linear 100.0% No
Bilstein Pro Susp. C/O 1999+ 242-282 242-282 Progressive 100%** No ** Front/Rear ratio will vary with compression on Progressive Springs
Cusco Zero-2 Coilover
336 280 Linear 83.3% Yes
Eibach Pro-Kit 89-'97 228 137 Linear 60.1% No
Eibach Pro-Kit 1999+ 228 137 Linear 60.1% No
Flying Miata ALL 342 228 Linear 66.7% No Different p/n for NA/NB Springs, same rates
Ground Control Coilover ALL 375 250 Linear 66.7% Yes
H&R 89-'97 240-270 220-260 Progressive ** No ** Front/Rear ratio will vary with compression on Progressive Springs
H&R 1999+ ?? ?? Progressive ** No ** Front/Rear ratio will vary with compression on Progressive Springs
Jackson Racing 89-'97 176 110 Linear 62.5% No
Racing Beat Street Kit 89-'93 209 111 Linear 53.1% No
Racing Beat Street Kit 94-'97 209 113 Linear 54.1% No
Racing Beat Street Kit 99-'00 207 145 Linear 70.0% No
Racing Beat Street Kit 01+ 207 145 Linear 70.0% No
Racing Beat Race Kit 89-'93 226 122 Linear 54.0% No
Racing Beat Race Kit 94-'97 226 124 Linear 54.9% No
Spax Coilover ALL 315 315 ?? 100.0% ??
Spec Miata ALL 700 325 Linear 46.4% No
Tein S-Tech 89-'97 235 168 Linear 71.5% No
Tein S-Tech 1999+ 235 173 Linear 73.6% No
Tein Type-HA Coilover 89-'97 280 224 Linear 80.0% Yes Springs same, but different dampening for NA/NB Type-HA kits
Tein Type-HA Coilover 1999+ 280 224 Linear 80.0% Yes NA/NB Top hats also different, but using pillowball upper mounts allows interchangeability.
Tein Type-Flex Coilover ALL 396 336 Linear 84.8% Yes Different p/n for NA/NB Springs, same rates
Tein Type-RA Coilover ALL 448 392 Linear 87.5% Yes Different p/n for NA/NB Springs, same rates
Tein Type-SS Coilover ALL 396 336 Linear 84.8% Yes Replaces Type-HA
Tuckin N1 Racing C/O ALL 672 616 Linear 91.7% Yes Different p/n for NA/NB Springs, same rates
Tuckin N1 "Tuned" C/O ALL 728 616 Linear 84.6% Yes Replaces Type-HA
