Post by kiwicanfly on May 26, 2013 5:29:43 GMT
We have now built several Rockets in house and none of them have suffered from bump steer. RTR I never thought of that point when considering the issue, when I go to get my certification I'll tell the inspector that he does not need to check for bump steer because the manufacturer says it does not exist - yes that will work I'm sure. Out of interest are there any figures available from measuring checks? What is not being taken into account here is how little the suspension actually travels during road use. RTR But is has the potential to travel until it hits limits. However without wanting to ruffle any more feathers let us just agree that the issue is not whether bump steer is present it is simply how much is acceptable and how much one wants to live with.
Post by huggy on May 26, 2013 22:34:48 GMT
More progress today: Right side panel trim fitted ... and the left.
Post by huggy on May 26, 2013 22:36:43 GMT
Front grill formed and sprayed satin black (...need to cut grass!) ...and fitted
Post by huggy on May 26, 2013 22:39:16 GMT
Side panels fitted Steering rack extension fitted.
Post by huggy on May 26, 2013 22:40:38 GMT
First fit of rad and master cylinders.
Post by huggy on May 26, 2013 22:41:57 GMT
12mm spacers made for the front callipers.
Post by huggy on May 26, 2013 22:46:08 GMT
Front callipers fitted. View showing spacer and resultant calliper position.
Post by Froggy on May 27, 2013 6:39:26 GMT
great progress there huggy! looking good too mate! wayne.
Post by Deleted on May 27, 2013 9:19:36 GMT
Getting there bud, rolling chassis soon eh??
Post by huggy on May 27, 2013 9:34:23 GMT
Cheers. I hope so. Bring on more long weekends :-)
Post by Froggy on May 27, 2013 17:41:46 GMT
there are never enough weekends!
Post by Paul (madeye) on Jun 15, 2013 21:46:55 GMT
Thanks Steve. Good to hear it works. Nice update in the tech section (the simulator is v.good). I had just updated the decals on the stalk, however may move the fog light to position three as you've suggested, keeping the wiring far simpler overall. how did you clean off the old print? and where did you get the new decals? cheers, paul
Post by huggy on Jun 15, 2013 22:34:48 GMT
Thanks Steve. Good to hear it works. Nice update in the tech section (the simulator is v.good). I had just updated the decals on the stalk, however may move the fog light to position three as you've suggested, keeping the wiring far simpler overall. how did you clean off the old print? and where did you get the new decals? cheers, paul Hi Paul, I carefully scraped off using a small flat watch/glasses screw driver. The stickers were an ebay item: 'Dash Sticker Sheet Boat Marine Race Rally Kit Car'I didn't find any true decals as such. These stickers are okay but you do see the surrounding plastic when stuck on. Cheers, Jason.
Post by huggy on Jun 24, 2013 21:43:39 GMT
A few more jobs (in no particular order): Rear wing stays fitted Rear callipers fitted ( note: wrong disc in picture, corrected already but no updated photo taken)
Post by huggy on Jun 24, 2013 21:45:58 GMT
A couple of pulley prepared if I need to reroute the handbrake cable later on. Fuel pump modification
