Post by jgilbert on Nov 13, 2013 19:30:32 GMT
Post by tlight on Nov 13, 2013 20:19:47 GMT
Thanks.
Post by jgilbert on Nov 30, 2013 23:44:49 GMT
So latest update. New toy purchased. Just have to learn how to use it now! Back to the build, like a number of others we have purchased some Photon headlights. Expensive but they do look nice. My only complaint would be that the wires from the back of the headlight could be neater and longer. So the plan was to fabricate a bracket that suited both the style of the exocet and the headlight. Decided to try to use round bar as the main bracket material. So ended up using 10mm solid bar. Hopefully IVA compliant. First job was to heat up the bar and bend it into shape. Old 2" pipe fitting seemed ideal for the job. Once we had formed the top frame of the bracket we cut and filed a piece of plate to the right profile. This is what the the headlight will attach to. Spent a lot of time experimenting to get the right shape for the main 'base' plate that will attach to the chassis and which the bar will be welded to. Ended up with this design. First mock up in the vice, prior to tack welding. Starting to look ok. Bottom support bar cut and tacked into position. Also you can see at the top, the inner plate that will be welded to the exocet frame and which the headlight bracket bolts onto. Trial fit on car (headlight thread needs to be reduced in length). Think its a bit different. Hopefully will look a nice job when welded up and powder coated. The 'open' style and using round bar is our attempt to mirror the chassis. Just indicators and side lights to think about now.
Post by biggunz on Dec 1, 2013 7:22:18 GMT
Looks great! Love it!
Post by tlight on Dec 1, 2013 7:25:12 GMT
Very nice idea!
Post by tom on Dec 1, 2013 9:28:44 GMT
Nice job. How did you get on with the welder? I'm planning on buying one and teaching myself so that I can weld various brackets etc to mine.
Post by jgilbert on Dec 1, 2013 16:17:52 GMT
Thanks for the positive comments.
Tom, re the TiG, early days yet but RTech units seem to get good reviews. It helps a lot if you can already gas weld as the arc creates the molten pool which you need to add filler to. Where as MIG the wire melts necessitating the need to add filler.
Still need to practise. Still better than Christmas shopping!
Post by jgilbert on Dec 7, 2013 13:36:08 GMT
Headlights done.
Post by gwnwar on Dec 7, 2013 17:19:54 GMT
Very nice job looks good and flows with the roll bar..
Post by jgilbert on Dec 8, 2013 14:40:30 GMT
So, made one of these today for the Exocet. Anyone got any ideas what its for ?
Post by gwnwar on Dec 8, 2013 16:35:59 GMT
Looks like it could be a nerf bar or plate holder for front of car
Post by tlight on Dec 8, 2013 16:58:13 GMT
Isn't it in the horizontal plane, so more likely anti grounding / skid feature ?
Post by mrjingles705 on Dec 8, 2013 17:12:34 GMT
I'm going to go with boot hinge (the straps at the bottom acting as a check).
Post by tlight on Dec 8, 2013 17:39:40 GMT
I've changed my mind - same as above Mr Jingles , but other end, bonnet
Post by jgilbert on Dec 8, 2013 20:38:04 GMT
Good effort people. So, it is a type of Hinge and its for the front of the car.
Any further ideas?
