Post by h5ngs on Aug 1, 2013 23:11:15 GMT
Well after being messed about waiting for a turbo to arrive finally got one from someone else a month later, still got an on going dispute at the moment ... anyway decided to fit a Honda civic radiator and fan so I can fit my rs turbo intercooler along side it the rad was a lot easier to fit than the mx5 one and looks good too Here's a quick preview It will be ready to pull apart again soon for powder coating
Post by gwnwar on Aug 2, 2013 3:12:27 GMT
That radiator look the same thickness as a MX5 one.. so you have lost 1/2 your coolant. why don't you put an intercooler in front of the radiator. they make IC all sizes. or run the tubes out the frame them back into the nose cone.. You start charging the engine you will need cooling.. What dia. hoses are you going to run to the IC. Why not have a rad shop modify the mx5 rad with 2 holes for the hoses to go through with new tubes for the missing one to join another tube to keep the flow going..
Post by h5ngs on Aug 2, 2013 7:53:10 GMT
I plan on running an alloy civic radiator which are thicker but wanted to see fitment first and mock up the design, the radiator with fan was only £30 delivered so worth a try, I've looked at front mount but pipes were an issue I initially was going to run non intercooled but then decided against it, I''m going to use a standard rs turbo intercooler for now (£15 delivered) and if I need to upgrade at a later date I can use a double core one in the same location. Also with this set-up it will make my intercooler pipework shorter. Only time will tell with the cooling, at worst I can wire the fan to a switch to have the fan running more often.
Post by gwnwar on Aug 2, 2013 18:39:12 GMT
Yes you can hard wire the fan in.. With only slight over heating it will take its toll on the engine.. Are you planning to race or really run this setup hard?? If so cool it better.. Have you thought of a thicker (at lest twice) alum. rad and use a pusher fan..
Post by h5ngs on Aug 3, 2013 10:30:44 GMT
The car will only be used for weekend driving so will never see hard track abuse, that's why my other mx5 is for This is more or a show off, sunny day, car show type car. I do plan on fitting the double core rad tho.
Post by h5ngs on Aug 8, 2013 21:30:57 GMT
Well it's up and running turbo power I've made a new coolant expansion bottle as space was tight but wish I had done this previously. For anyone wanting to make one it was simple and cheap aluminium drinks bottle £3.49 bottle holder £1.99 Original return tube £0 8mm plastic tube £0 got from work but mega cheap anyway 2 x 90 degree grease nipples £0 got from work but again pennies each Short piece of brake pipe free with the kit and most people will have left overs from there builds Right cut the top off the drinks bottle cap so it is flat, Drill two holes in to screw in the grease nipples Drill out the ball bearing of the grease nipple and enlarge the hole Drill out on of the bottles of the grease nipple on the threaded part Fit the grease nipples into the cap Measure the brake pipe length to the bottom of the bottle leaving 1cm Tap the pipe into the grease nipple you enlarged Screw on the cap Using the original pipes cut 2 2cm pieces of 8mm tube and insert them into the end of the pipes Push the pipes onto the grease nipple ends Fit bottle holder to your chosen mount Insert bottle job done New vs old Bottle fitted Right that was one update Main update is that the turbo is fitted and running Few more parts are on order and then can plumb up the intercooler and dump valve, sort exhaust and rear tub brackets, then ready for the strip down and powder coating Can't wait to give it a road test
Post by h5ngs on Aug 17, 2013 23:50:48 GMT
Post by red5 on Aug 18, 2013 8:54:10 GMT
looks nice mate
stubbers
Exocet Number 306
Post by stubbers on Aug 18, 2013 16:24:06 GMT
I see you've got the original ECU still in what are you doing for the fueling??
I plan to turbo mine after i turn 21 and the insurance will drop
Rich
Post by h5ngs on Aug 18, 2013 19:51:14 GMT
Bipes acu and jr rrfpr, then once all the initial build costs and registration costs are over megasquirt ecu and loose the afm and run bigger intercooler and alloy civic radiator centre mounted. 7psi for now tho which should still make 180bhp
Post by welshy1 on Aug 18, 2013 22:14:07 GMT
Looking good nice to see some FI build on the go. Im planning on going supercharged after the iva next winter 250bhp would be awesome.
Post by tomaff on Aug 19, 2013 14:50:52 GMT
Getting 250 from the supercharged side although no impossible is a lot harder than the turbo route. 200bhp or less, stick with a supercharger, 250bhp go for a turbo.
T
Post by h5ngs on Sept 1, 2013 16:10:16 GMT
Post by gwnwar on Sept 2, 2013 5:46:49 GMT
You may want to go to a RX7 AFM it is large for more intake air.. You just have to adjust the tension on the spring for the flap door under the black side cover.. Is that air filter going to allow enough air where it is located up to the firewall..
Post by h5ngs on Dec 1, 2013 21:56:37 GMT
