Post by edwinwl on Feb 15, 2013 19:45:37 GMT
Before cleaning head lights: After cleaning head lights: 4x M6 bolts to take the nosecone off: Next job is to clean up this spaghetti:
Post by erik on Feb 16, 2013 8:05:13 GMT
You really have been updating your tR1ke lately! Do you have more modifications planned? Looking forward to your progress!
br, Erik
Post by edwinwl on Feb 16, 2013 9:37:05 GMT
One future project can be: paining all blue parts into some fancy flashy metallic blue. Just an idea..... Original, plain tR1ke: V -striped tR1ke: ^ -striped tR1ke: = -striped tR1ke: || -striped tR1ke: | | -striped tR1ke: | + | -striped tR1ke: left | + | -striped tR1ke:
Post by erik on Feb 16, 2013 10:15:10 GMT
Wow, lotsa options here! Hard to make a choice. With my wheels it worked quite well to cancel out the ones I didn't like which left only a few good alternatives. I think you need to proceed like this too.
Yeah flashy metallic sounds good! might be nice to add spikles to the metallic. I recon orange might be wild but clear aluminum can be nice too. For my bonnet I did reconsider metal flakes (wide variety in colors!) but the many layers of clear coat may crack underheat on a polyester surface which lead to gun metal for me.
nice thoughts!
Erik
Post by erik on Feb 16, 2013 10:19:02 GMT
Hmmm, clevage V-style, coming along from the sides to the centre front might suit these checkered strips too. give it a try!
Post by edwinwl on Feb 22, 2013 20:18:59 GMT
All electronics works very well, time to finalize the wiring under the nose cone. Labeled all wiring, can be handy for future diagnosing or modifications. I used original bike wiring with car donor steering column switch. I used no extra relays. For other current and future Tr1ke builders: With this configuration basically all wiring "intelligence" is at this location. Easy accessible high up in the nose. From this location I extended all wiring to the engine. In total I used 4x 7 wire poly urethane cable also used for car trailers. PU cable is very robust and can handle higher temperatures than standard PVC isolated cables. Not unimportant: PU cables are widely used therefore relative cheap. I recommend this configuration of wiring. Added switch gear: - Hazard switch
- Engine kill switch
- Engine start switch
- One fuse for powering hazard switch and 12v plug.
Before: After:
Post by Deleted on Feb 23, 2013 9:38:30 GMT
I never like to look under my dash, the wires make for an interesting looking city on mine, or more like a spaghetti explosion :-)
Yours is very neat :-)
Post by edwinwl on Mar 2, 2013 16:35:23 GMT
Installed a gear indicator and got a fancy key hanger:
Post by edwinwl on Mar 2, 2013 16:39:51 GMT
Rik pointed me out that licence plate legislation has changed in the Netherlands. (starting January 2013) Motorbike format is now allowed. So I exchanged my old plate 11x52 cm by a new one 14x21 cm. It meant I had to change my rear frame... As in the picture it is the lowest position legally allowed. (5 degrees of free sight downwards.)
Post by Deleted on Mar 3, 2013 12:05:12 GMT
Have you painted that steering cowling with Tar? It does not seem up to the standard you have built the TR1KE to? :-)
Post by edwinwl on Mar 3, 2013 12:50:19 GMT
No tar. Black glossy hammerite paint... (it's the only black paint I have, for the moment) It's recession over here, So I can't afford a can of black mat paint.
Post by slugshot on Mar 3, 2013 13:00:16 GMT
I feel sorry for the goldfish in the key ring he has to look at it 24hours a day ;D.
Post by Deleted on Mar 3, 2013 16:20:03 GMT
I feel sorry for the goldfish in the key ring he has to look at it 24hours a day ;D. Thats funny, yes its a recession over here too.... :-)
Post by edwinwl on Mar 3, 2013 17:17:57 GMT
You are also looking through the window 24h /day?
:-P
Post by edwinwl on Mar 3, 2013 17:19:14 GMT
BTW it's no goldfish.
