Post by slugshot on Aug 14, 2012 21:29:18 GMT
Hi Edwin, you will probably find your clutch ok once you put a teflon lined cable on. I had a similar problem with a non teflon lined throttle cable, it totally transformed it with a lined cable. Also have you changed the cable position on your clutch peddle, I moved mine to about 35mm from the pivot to try and make the action less in or out, it seemed to have helped with a lot less stalling when pulling away and i think its lighter to depress as well. Cheer, kev
Post by edwinwl on Aug 18, 2012 16:53:20 GMT
While waiting for my clutch cable, I aligned my car. First I added about 85kg of mass. Then the alignment as discribed by vtRik: The space between both lines is 190 cm. RR2 = RR1 = RL1 = RL2 = 86,6 cm FR1 = FL1 = 7,4 cm FR2 = FR2 = 8,9 cm FR3 = FR3 = 6,8 cm Camber is about 1cm in (negative camber). Measured on the rim. Down is out, up is more in. Will see how the tr1ke will handle.... Tryed to reroute clutch cable. No really effect. Removed the cable. Redesigned parking brake bracket and clutch stopper bracket. Old ones were bend.
vtR1k
I'm a trike lover...
Post by vtR1k on Aug 19, 2012 16:31:43 GMT
From my experience, 6 mm difference between Flr1 and Flr3 each wheel (=12 mm in total) is extremely much... I think you should bring it back to about 1 mm each wheel... Normal road setting for a car is mostly 0 mm...
Post by edwinwl on Aug 19, 2012 21:00:53 GMT
I have no car align experience. (I am just a humble salesman.....)
Thank you for suggesting! It's appreciated. Will let you know about my findings.
Sent from my GT-S5660 using proboards
Post by edwinwl on Aug 21, 2012 10:43:46 GMT
Using my calculator.... 15" frontwheels => 381mm diameter of the wheel rim 6 mm on 381 mm = (tan-1(6/381) = 0.90 degrees 4 mm on 381 mm = (tan-1(3/381) = 0.60 degrees 2 mm on 381 mm = (tan-1(3/381) = 0.30 degrees 1 mm on 381 mm = (tan-1(1/381) = 0.15 degrees 0,5 mm on 381 mm = (tan-1(1/381) = 0.075 degrees After vtRik his suggestion did some extra Google, I found a few hyperlinks: www.hotrod.com/techarticles/chassis/hrdp_0411_wheel_alignment_guide/viewall.htmlwww.tirerack.com/tires/tiretech/techpage.jsp?techid=4Rear wheel drive (toe in) examples: Mazda Miata / MX5: toe in: 0,075 degrees Ford F150: toe in: 0,100 degrees Triumpf spitfire: toe in 0,8 to 1,6mm Front wheel drive (Neutral or toe out) examples: Toyota Camry: -0,1 to 0,1 degrees
Post by edwinwl on Aug 24, 2012 14:17:55 GMT
Fitted new clutch cable and aligned the car. Made a few test runs.
Clutch is perfect now (as predicted by Slugshot) and this car is fast........
It almost scares me. ;D
Post by edwinwl on Aug 27, 2012 18:14:36 GMT
Hmm. Today took the tR1ke for a ride. This afternoon the engine runs on 3 cylinders....
Will change the spark plugs...
vtR1k
Post by vtR1k on Aug 28, 2012 7:27:34 GMT
Auch... I advise you to find a manual somewhere. I bought a digital one on Marktplaats, for €7,-. Otherwise, order a Haynes Manual... Indeed, start with the spark plugs. When you remove the old ones, the faulty cylinder should have a abnormal coloured spark plug. Normal colour is a kind of coffee cream alike. You can find in the internet somewhere what abnormal colour comes with what common problem. Good luck...
Post by edwinwl on Aug 28, 2012 16:08:14 GMT
Yes I know. First new spark plugs. Second is bombine wire check. Third is carburator cleaning. I do not have time for. Will see. Sent from my GT-S5660 using proboards
Post by Deleted on Aug 28, 2012 16:20:13 GMT
Also check the Coils, and Coil leads
Post by edwinwl on Aug 29, 2012 5:14:22 GMT
Also check the Coils, and Coil leads I think your coils and my bombines are the same. The transformers that creates the high voltage for the sparks plugs to spark. Sent from my GT-S5660 using proboards
Post by Deleted on Aug 29, 2012 12:40:10 GMT
Yeah sounds about right, you found the source of it yet?
Post by edwinwl on Aug 29, 2012 18:23:34 GMT
4 new spark plugs did the job.
Now changing oil and filter. Oil is out. Engine is cooling down.
Advise for builders: service your engine before it is build into the Tr1ke.
Post by Deleted on Aug 29, 2012 18:51:42 GMT
Yes, I need to get a clutch at some point, so knowing that this means dropping the engine in the frame, I will replace it with a Barnett clutch and may even fit a new Stator.
Post by erik on Aug 29, 2012 19:17:55 GMT
4 new spark plugs did the job. Now changing oil and filter. Oil is out. Engine is cooling down. Advise for builders: service your engine before it is build into the Tr1ke. Sent from my GT-S5660 using proboards Hey Edwin, Good to read your enging is doing fine now. I'd like to know if there is a magnet on the M14 bolt? I Purchased a oli Temp sensor but I am wondering where to place it. Removing a magnet seems to be a nono IMHO. I am not able to empty my engine without having my chasis at home for inquiries. thx. Erik
