Post by doubletrouble on Nov 11, 2019 13:38:33 GMT
Just a thought.... If you start it up and then keep turning the key on and off quickly, will it keep running? Hi. Tried and tried to keep it running by flicking the ignition on and off to no avail. It will keep running if i flick the ignition inside the 2 seconds but after that it dies as before. Immobiliser?
Post by Stiggy on Nov 11, 2019 15:38:23 GMT
Just a thought.... If you start it up and then keep turning the key on and off quickly, will it keep running? Hi. Tried and tried to keep it running by flicking the ignition on and off to no avail. It will keep running if i flick the ignition inside the 2 seconds but after that it dies as before. Immobiliser? just click on the link I put up for you
Post by doubletrouble on Nov 11, 2019 16:50:34 GMT
Hi. Tried and tried to keep it running by flicking the ignition on and off to no avail. It will keep running if i flick the ignition inside the 2 seconds but after that it dies as before. Immobiliser? just click on the link I put up for you Hi Stuart, Been there and done that. Bought an ECU etc. Swapped it all out. Made no difference. Im considering getting an ME221 ECU. Whats are the odds it will work ok then?
Post by Stiggy on Nov 11, 2019 17:32:29 GMT
I read that you had tried another ecu and key. But did you swap the key reader around the ign barrel, it's connector and the immob unit and check connectivity of the associated cables and grounds?
If you have a spark after it cuts out and the pump is still running causing fuel to squirt from the injectors then it has to run. Well that is assuming the fuel pipes are the right way around i.e pump centre pipe to the opposite end of fuel rail to the regulator?
I doubt it will be an air leak as a missed off vacuum pipe doesn't usually kill it all together, have a good look around the plenum though, you never know.
Post by doubletrouble on Nov 11, 2019 18:30:52 GMT
I read that you had tried another ecu and key. But did you swap the key reader around the ign barrel, it's connector and the immob unit and check connectivity of the associated cables and grounds? If you have a spark after it cuts out and the pump is still running causing fuel to squirt from the injectors then it has to run. Well that is assuming the fuel pipes are the right way around i.e pump centre pipe to the opposite end of fuel rail to the regulator? I doubt it will be an air leak as a missed off vacuum pipe doesn't usually kill it all together, have a good look around the plenum though, you never know. Hi Stuart. I am aware of the key sensor and little.black box. Swapped out everything. The pump may be running but it does seem that when the engine dies there is no fuel getting through. Wish someone new what the immobiliser does to stop the engine.
Post by ian85 on Nov 11, 2019 18:32:48 GMT
Have you got a 3 pin coil or 4 pin?
Post by doubletrouble on Nov 11, 2019 19:05:50 GMT
Have you got a 3 pin coil or 4 pin? Hi. The coils are 3 pin.
Post by Stiggy on Nov 11, 2019 20:54:16 GMT
I read that you had tried another ecu and key. But did you swap the key reader around the ign barrel, it's connector and the immob unit and check connectivity of the associated cables and grounds? If you have a spark after it cuts out and the pump is still running causing fuel to squirt from the injectors then it has to run. Well that is assuming the fuel pipes are the right way around i.e pump centre pipe to the opposite end of fuel rail to the regulator? I doubt it will be an air leak as a missed off vacuum pipe doesn't usually kill it all together, have a good look around the plenum though, you never know. Hi Stuart. I am aware of the key sensor and little.black box. Swapped out everything. The pump may be running but it does seem that when the engine dies there is no fuel getting through. Wish someone new what the immobiliser does to stop the engine. the immob cuts spark, fuel cuts if ecu senors no engine rotation and assumes the car is in a ditch. Try overriding pump relay or stick a pos on the pump, careful though, sparks and petrol should only be mixed in the combustion chamber
Post by doubletrouble on Nov 11, 2019 21:16:53 GMT
Hi Stuart. I am aware of the key sensor and little.black box. Swapped out everything. The pump may be running but it does seem that when the engine dies there is no fuel getting through. Wish someone new what the immobiliser does to stop the engine. the immob cuts spark, fuel cuts if ecu senors no engine rotation and assumes the car is in a ditch. Try overriding pump relay or stick a pos on the pump, careful though, sparks and petrol should only be mixed in the combustion chamber Hi and thanks for the info. I know for sure that the spark keeps going and the pump also. I can hear the pump run on after the engine dies. I have also jumped fd and ground to make sure. So it can't the immobiliser if the spark continues. Why would the injectors stop?
Post by ian85 on Nov 11, 2019 23:20:20 GMT
Been looking at the wiring diagram and I wondering if there's a wiring fault between afm and ecu. Not 100% sure but looks if ecu doesn't see air flow it stops the injectors.
Post by doubletrouble on Nov 11, 2019 23:36:21 GMT
Been looking at the wiring diagram and I wondering if there's a wiring fault between afm and ecu. Not 100% sure but looks if ecu doesn't see air flow it stops the injectors. Makes sense. I will check direct connections from afm to ecu. Many thanks Ian
Post by Stiggy on Nov 12, 2019 11:14:52 GMT
the 1.6 MK1 has a flap in the AFM so without air flow the pump cuts off. This feature is to cut fuel in the event of an accident. The same applies to the later cars but is done electronically not via the troublesome 1.6 flapper. As you say you have tried another AFM you may be getting close.
Post by doubletrouble on Nov 12, 2019 19:10:52 GMT
Been looking at the wiring diagram and I wondering if there's a wiring fault between afm and ecu. Not 100% sure but looks if ecu doesn't see air flow it stops the injectors. Makes sense. I will check direct connections from afm to ecu. Many thanks Ian The WHT/RED wire looks likenit has a lot to say! Ill trace that bugger later.
Post by jasonthorpe on Nov 14, 2019 5:00:38 GMT
Hi Double
You say you go to Nuneaton from Norfolk a few times a month. I live near Spalding, a bit of a detour but if it helps!, so if you need a loan of a part for a few weeks or so to save buying bits you might not need I might be able to help you out.
I don't look at the forum very often but I'm on the facebook page if you want to get in touch and arrange something.
Good luck
Jason
Post by morrin88 on Nov 14, 2019 17:03:40 GMT
How are you getting on@doubletrouble? Issue still occurring for you?
I’ve not pulled the trigger but ME have 10% off on the ME221 at the moment for Black Friday so possibly pull the trigger. I think my issue is immobiliser and I believe the me221 will get around that
