Post by Fin on Nov 30, 2017 14:25:25 GMT
Thankyou Fin, thought I was loosing it as there were two pipes from tank so return must connect to canister ?? I will see if gwnwar has the answer and best way forward hope your on the mend The send & return pipes connected at the tank end by a T-connector, as in the link below, and then just the one pipe to the rail? The filter fit in to the send pipe before the T-connector. mevowners.proboards.com/thread/9075/99doner-fuel-lines-emmisions?page=1&scrollTo=99124
Post by p2tav on Nov 30, 2017 20:22:47 GMT
thanks fin, that looks like it would work but I'm sure there were two lines from front to back just not sure how they were connected:( if I cant figure it out I will try the way you have suggested thanks
Post by Stiggy on Nov 30, 2017 20:43:51 GMT
NEWS FLASH Your G-type GRP will be collected for our lam shop in 10 hours and 17 minutes.
Post by Fin on Dec 1, 2017 14:28:38 GMT
thanks fin, that looks like it would work but I'm sure there were two lines from front to back just not sure how they were connected:( if I cant figure it out I will try the way you have suggested thanks Let me know, I'm about to do mine in the next few days
Post by p2tav on Dec 1, 2017 22:36:57 GMT
thanks fin, that looks like it would work but I'm sure there were two lines from front to back just not sure how they were connected:( if I cant figure it out I will try the way you have suggested thanks Let me know, I'm about to do mine in the next few days hi fin i have worked it out i think? i have sent you a personal message
Post by p2tav on Dec 2, 2017 16:29:12 GMT
Post by p2tav on Dec 3, 2017 18:51:37 GMT
Post by aterro on Dec 3, 2017 19:11:54 GMT
Looks good Paul! Good luck with collecting your kit! Mine should be done shortly too! Let me know if you see it Do the 2017 models still require the banana attachment on upper wishbones?
Post by p2tav on Dec 3, 2017 23:57:09 GMT
Looks good Paul! Good luck with collecting your kit! Mine should be done shortly too! Let me know if you see it Do the 2017 models still require the banana attachment on upper wishbones? hi aterro, thanks for the comments i do believe they require the banana as i understand the shocks are at a slightly different angle to the mx5 and they will catch. i think it all depends on the shocks that your using. i just decided to do it while i was waiting . cheers
Post by p2tav on Dec 5, 2017 17:18:54 GMT
Well tomorrow is the big day!! picking up my kit cant wait been trying to sort the garage out but failing miserably I'm just trying to work out how many times I will put the frame on and of I have to sort the exhaust and the clearance for the vvt on the top of the engine I think it will be 6 times before I finally bolt it down any advance on 6 happy days
Post by mikeeyboy on Dec 5, 2017 18:23:28 GMT
I lost count how manny times I took the chassis on and off!
Post by p2tav on Dec 6, 2017 15:13:56 GMT
Post by p2tav on Dec 6, 2017 15:18:55 GMT
Post by gwnwar on Dec 6, 2017 18:19:52 GMT
Nice striking color should show good with the silver.. FYI the rear end underside brace in the pic you will have to cut off the front 2 legs and cross bar from it. They are not used in the install..
Post by p2tav on Dec 6, 2017 18:26:54 GMT
Nice striking color should show good with the silver.. FYI the rear end underside brace in the pic you will have to cut off the front 2 legs and cross bar from it. They are not used in the install.. Thankyou gwnwar, I was not sure what was needed ill get cutting and see how I get on:)
