Post by p2tav on Oct 17, 2017 17:59:10 GMT
I have noticed that people are putting nut covers over the ball joints on the track rod ends does this have to be done for IVA and if so what about the split pin
Post by mikeeyboy on Oct 17, 2017 19:11:45 GMT
I used a thin split pin that you bend out at the end. You would still get a cover over it.
Post by Stiggy on Oct 17, 2017 21:05:58 GMT
or replace the nuts with nyloc's. Theye are metric, think it is 10 mm with 1.5 pitch
Post by p2tav on Oct 18, 2017 23:29:37 GMT
hi All,
just looking at buying a rivnut gun has anyone any experience of using them and will they all do stainless steel or just the really expensive ones?
Post by mikeeyboy on Oct 19, 2017 6:26:32 GMT
Paul, I made the mistake and bought the cheap one from machine mart. Most of the dyes have broke after 2 rivets. Reading online everyone moans about them. I have used a couple of nuts and bolts on most of mine to pull them tight, it's just a bit slower. If I was going to get another it would be something like this www.cromwell.co.uk/shop/hand-tools/riveters/professional-rivet-nut-inserter/p/KEN5693080KFor stainless ones that is definitely better than the hand squeeze ones
Post by p2tav on Oct 21, 2017 19:21:54 GMT
Gents, can anyone tell me if you need the key fob when i come to starting the car as i have been asked by someone if they can buy it from me and i dont want to let it go if it will stop me from starting the car ? does it control the immobilizer or is it the key that sorts that out ?
Post by p2tav on Oct 25, 2017 14:22:56 GMT
Post by bewgy on Oct 25, 2017 16:02:30 GMT
Looking very good Paul, I have been following your build. I have just dismantled the front and back ends. Now deciding whether or not to replace the bushings. It looks like you went with the more cost effective version, floflex bushes. I have read varying reports on these. How did you get on, did they fit up ok? I dont think I can justify paying £400 for a rubber set, the floflex are much cheaper.
Post by p2tav on Oct 25, 2017 18:04:25 GMT
hi Dan, The floflex bushes are a good fit I paid about £80 for the full set as they were on offer. I read mixed reviews but as I'm not planning on using mine on the track or doing 50,000 miles I think they will be fine. They were really easy to fit as they are split so they just push in from both sides, I just use pipe fittings to push the old ones out with a vice and a piece of pipe to extend the vice bar. It was quite easy to do as I did not have access to a press. your build is looking good it looks like your coming on nicely where in the country are you? have fun
Post by p2tav on Oct 26, 2017 22:47:17 GMT
Well Gents, Next decision made i have decided to go with Mikeeboys idea of using flexy braided brake pipes from front to back and across the power steering pump. (cheers mikeeboy). i have asked the question to the IVA and they say that it would be ok to do this and i have also decided to use flexy braided fuel hose on my flow and return (thanks again mikeeboy) i call this pinching with pride . it will cost around £235 for the kit of fittings and hoses which when you add in the brake flare tool, fittings and brake hose not to mention fuel lines and clips, it works out not much more money and will save me from doing some extensive pipe bending .
Post by p2tav on Nov 24, 2017 16:14:07 GMT
hi fellow builders, I've not posted for a while as i'm awaiting the call to pick up my Kit I have discovered something that might be of interest to you all I have found a company in Mirfield west Yorkshire that you will have heard of called ASH silicone hoses. whilst I was at there showroom was discussing the build and we were talking about induction kits when they said they make them on site so I asked them to give me a quote and I was pleasantly surprised!! I took my existing air box and pipe work down and they made one for my car that allows all you need to plug and play:) I just had to buy a breather plug to fit which I used a brake fitting that cost me a whopping £1 lol. the air filter has a cover over it which will allow you to connect the air sensor from your old air box and use the rubber grommet to make it look the business:) also might help with shielding the heat from the manifold. The induction kit comes in a range of colours and as the K&N one is £300 ish I was expecting it to be quite expensive but to my shock it works out at £53 all in including the hose clips I thought this was worth sharing. cheers
Post by p2tav on Nov 24, 2017 19:07:07 GMT
Wheels, I have found a company in Bradford that powder coat wheels for £1 per inch. I thought this might be too good to be true but I thought I would give it a go !! the wheels were really badly marked and scuffed to the point that I thought they would be no use. I dropped them off and was told to return in 3 days, I was not sure what to expect but to my surprise they were mint they had cleaned them up and they have done a fab job of coating them i could not be happier. the company is called CAS Coatings and yes they charge £1 per inch. I have just had new tyres fitted and they look like new
Post by p2tav on Nov 29, 2017 19:21:38 GMT
gents, I have a mk2.5 vvt 1.8 engine but cant figure out the fuel lines as the engine only has one pipe on it that I can find and ive looked at my pictures but cant find where the fuel return pipe connects?. I have looked all over the web but cant find the answer can anyone help as its different to the standard mk2 engine. the canister has more pipes and I cant for the life of me figure out how it was before I took it off?
Post by Fin on Nov 29, 2017 19:49:25 GMT
Mk2.5 only has a single common feed pipe, rather than dual, so don't worry. I've been off ill some time, but I'll look up the relevant info from gwnwar
Post by p2tav on Nov 29, 2017 19:59:48 GMT
Thankyou Fin,
thought I was loosing it as there were two pipes from tank so return must connect to canister ?? I will see if gwnwar has the answer and best way forward
hope your on the mend
