Post by ecliptics on Sept 8, 2011 10:08:30 GMT
A bit of Tcut and it will be fine!
Post by ecliptics on Sept 8, 2011 10:13:26 GMT
It's not that I am gagging for the kit to arrive, but...........
Post by ecliptics on Sept 8, 2011 10:16:28 GMT
Kit arrives....
Post by ecliptics on Sept 8, 2011 10:19:15 GMT
It rolls.
Post by ecliptics on Sept 8, 2011 10:27:37 GMT
The Engine is in.
Post by andychalmers on Sept 8, 2011 13:03:22 GMT
Love the pic of the 4 wheels and engine, made me chuckle lol. Dont forget to drill the engine cover holes before fitting the engine. I used rivnuts.
Post by motorhead on Sept 8, 2011 13:50:34 GMT
Tasty exhaust manifold you have there!
Post by ecliptics on Sept 8, 2011 21:28:10 GMT
Thanks for the advice guys, allways welcome.
MevST
Road Warrior
Post by MevST on Sept 9, 2011 7:51:53 GMT
Looking good matey, did you have any probs with the manifold fitment? i bought the same manifold to start with and it caught on the chassis at the top and the bottom A wad of cash and RTR's outstanding help custom made the manifold/cat and silencer! Have fun with other ST problems itll test ya! but BOY is it worth it! Ade
Post by ecliptics on Sept 10, 2011 8:40:30 GMT
Hi Ade,
Yep the manifold was too long, I had to shorten it to make it clear the frame. Kind of expected that to happen though!
Post by goldie on Sept 18, 2011 15:03:41 GMT
nice job on the engine clean and painting looks spot on
Post by ecliptics on Sept 19, 2011 20:21:17 GMT
Some more pics...on the off chance anyone is interested! Gear selector reversed for the Getrag 6 speed.
Post by ecliptics on Sept 19, 2011 20:28:16 GMT
And the Krypton factor bracket at the other end. The selector has been rotated 90 degrees so the cables can run over the top of the gearbox. they then avoid the exhaust and only have 2 bends. so far it seems really smooth. Many thanks to the genius that came up with that idea.
Post by ecliptics on Sept 19, 2011 20:29:54 GMT
The steering ext.
Post by ecliptics on Sept 19, 2011 20:33:35 GMT
The engine mount had to be moved 12mm up and about 40 mm back, hence the thick ali plate, only took a day to cut that puppy out!
