Post by ecliptics on Sept 19, 2011 20:35:40 GMT
Coming on though
Post by ecliptics on Oct 4, 2011 21:18:27 GMT
Some more pics, Slow progress, there is still a shed load to do!
Post by ecliptics on Oct 4, 2011 21:22:01 GMT
Post by ecliptics on Oct 4, 2011 21:26:49 GMT
The pulleys to offset the handbrake cable have been lying around in the garage for about 10 years!...Finally have a home.
MevST
Road Warrior
Post by MevST on Oct 5, 2011 17:49:39 GMT
Looking good matey! build is looking nice
Post by ecliptics on Nov 10, 2011 17:20:46 GMT
I can't believe it but it fired up first time.......Given all those wires it's a miracle really!.....I nearly passed out.
Post by ecliptics on Nov 10, 2011 17:24:35 GMT
Post by ecliptics on Nov 10, 2011 17:33:57 GMT
With an electric water pump the drive belt has gone from over 2meters to just 90cm!
Post by Andy Patey on Nov 11, 2011 10:27:34 GMT
Looking lovey mev meta
Post by Deleted on Nov 11, 2011 16:38:58 GMT
Sweet.. Im going the external water pump route myself as i've one kicking around. Have you mounted it on a bracket, or is it mounted just by the inlet/outlet?
Post by ecliptics on Nov 13, 2011 21:44:39 GMT
I thought about mounting it on a bracket, but the instructions specifically say it is light enough to be supported by the pipe, it seems fine with no bracket.
Post by Deleted on Nov 14, 2011 13:58:56 GMT
I suppose as long as the engine mounts are tight, and your plumbed in as you are, then it should be ok. With sloppy mounts, it could stress the pump casing. Your pump looks a little bigger than mine also. The ASH hoses are awesome value for money too, Ive just used them on my last project. Really good quality! Keep up the good work!!
Post by ecliptics on Nov 15, 2011 19:06:16 GMT
So what is the general consensus on the Camshaft cover vent, the one that used to connect to the air filter.............
Not sure whether to feed it back into the intake or not.
Any advice would be much appreciated.
ollieballs
st170 rocket tuned to 200bhp
Post by ollieballs on Nov 15, 2011 19:24:59 GMT
i ran both breathers into a catch tank.. im using jenveys so they dont have a breather inlet.. but the tank does have a magnetic plug to spot any cam problems early
Post by brownie on Nov 17, 2011 17:58:18 GMT
Hi mate, I've got the same cooling set up as you but I've noticed too have not plumber in the oil cooler. Just curious why you have left it out. Have u just blanked it off ?
