Post by stuli on Apr 18, 2019 10:56:13 GMT
Post by stuli on Apr 18, 2019 11:12:20 GMT
Post by stuli on Apr 20, 2019 13:50:20 GMT
Lots of info in the forum already but for my input I think the following tools and equipment are very useful (on top of regular tool box tools) Breaker bar minimum 1/2” with a means of extending (I used a old metal table leg) Blow torch for those stuck fast bolts Old baking tray to act as heat guard when using blow torch Penetrating fluid (not wd40) a proper fluid Engine hoist (bought mine on eBay new for £99 and can easily sell again for near that which makes it much cheaper Than hiring Appropriate straps or chain for donor body and then engine Lifting shackles Oil and fluids catch pots Lots of gloves and different sorts (fluid resistant / hard wearing etc) Safety glasses and proper goggles for grinding Masks Impact driver with 12,14,17&19mm sockets Extension bar for impact driver Good size vice helps Cable tie markers (cable ties with space for writing on) Thin sharpie Plastic bags Lots of rags Something to kneel on Inspection lamp Wire brushes Wire wool Chemical blacking kit Paper and pens (write everything that needs replacing) Camera (cannot take enough pictures) Bungee cords for hanging bits up Haynes manual Access to the internet (so often checking the reward in saving a part vs buying a new or reconditioned one!) Long cable ties (also useful for using with a rubber glove to cap off pipes and exposed bits that need keeping clean) Printed picture of an Exocet (inspiration and forever explaining what I’m building)
Post by chrisbucks1 on Apr 21, 2019 21:39:26 GMT
Hi I'm just down the road in aylesbury if you want to see a finished car or if you want a hand with anything .
Post by stuli on Apr 21, 2019 22:18:01 GMT
Hi I'm just down the road in aylesbury if you want to see a finished car or if you want a hand with anything . Thanks Chris I really appreciate that. I am going to Stoneleigh to have a good look around but would certainly like to have a good talk with someone local who’s already been through it. Will see if you are a available sometime before I start in anger on the the kit which should be some time in May hopefully.
Post by stuli on Apr 22, 2019 10:57:19 GMT
Well the list of parts needed continues to grow..... Wish bone bolts rear lower Exhaust gasket Track rod ends Drop links Clutch kit inc. main seal Clutch alignment tool Gear lever lower boot Discs Pads Ignition leads Oil filter Fuel filter Brake pipes Fuel line Spark plugs Induction kit CAS seal Rocker cover gasket Front calliper kit Clutch master cylinder rebuild kit Non abs brake master cylinder Gasket paste Pedal covers
Post by stuli on Apr 29, 2019 10:57:40 GMT
Like most people I struggled with removing the lower wishbone/hub bolts. I could rotate the bolts but there was no way it would ever go through due to the corrosion on the exposed section. My solution was to angle grind both ends off as close to the hub as possible and then I drilled out the middle section of the exposed shank enough that I could then persuade (with a massive hammer) the 'good' ends to go through. It was a real pain but it did work better than trying to get the corroded ends to push through. I don't think there is any good answer to this poor design. To make sure I don't have this problem in the future I chemical blacked the replacement (used) bolts. imgur.com/1BVLZCK
Post by stuli on Apr 29, 2019 11:01:58 GMT
I have seen this in some other threads but a good cheap hack to remove or greatly reduce the effort in removing rust is to use vinegar. I was skeptical but after 72 hours soaking the vinegar dramatically softened the rust to make wire wheeling it much easier. It also removed the loose plating. Well worth a go. I did follow it up with some Hammerite rust remover for good measure as I already had some but it was a great base for chemical blacking.
Post by stuli on Apr 29, 2019 11:44:09 GMT
Another issue I had was removing the bolts for the front brake heat shields. The heads came off easy but the rest of the bolts (all 6 of them) were completely seized. This is were friends with access to proper workshops come in handy! bbcode imagewaiting to see if just a re-tap or Helicoils needed?
Post by mprmurray on Apr 30, 2019 11:08:17 GMT
I had the same issue with these as well as the ABS bolts - leave these well alone if you can they all sheared of on me. Saving grace was Aldi currently have a die and tap sets for less than £20 and they seem adequate enough as enabled me to re-tap the holes. just use plenty of cutting oil.
Post by scottmev on May 2, 2019 19:27:55 GMT
Hi I don’t use the forum too much now but I am in kempston with a finished Iva example. If you ever need help/advice.
Post by stuli on May 8, 2019 10:43:23 GMT
Hi I don’t use the forum too much now but I am in kempston with a finished Iva example. If you ever need help/advice. Hi Scott, Thanks for the offer I certainly would appreciate some help when I inevitably lose the plot
Post by stuli on May 8, 2019 10:51:36 GMT
I was not sure if to remove the power steering or not but after a trip to Stoneliegh on the weekend I thought I will commit to de-powering the rack. Bit of a messy task but I did get it done. Luckily I have a friendly supplier of metal fabrication at my work and they welded the shaft to remove the play although it was very small. I need to set the pre-load as it is a bit heavy but hopefully this is easy to do (the nut and lock nut are fairly well seized together). Does anyone have any advice on either the process for setting the pre-load or how to judge what is acceptable?
Post by chrisbucks1 on May 13, 2019 22:23:15 GMT
Hi mate I'm just down the road in Aylesbury with a car that's just passed iva .if you need a hand with anything gimme a shout
Post by stuli on May 14, 2019 11:40:22 GMT
Picked up my kit last Thursday on my 40th Birthday. Stuart and Julie put the icing on the cake for me - Great surprise cheers!
