Post by mikeeyboy on Aug 14, 2018 8:03:14 GMT
I fitted a 5 quid plate fully engraved from ebay, they do not need to be expensive. Just a specific size. I bought mine from a trophy engravers.
jayz101
Junior
Brake time
Post by jayz101 on Sept 8, 2018 20:07:14 GMT
Alternatively, make your own. I think that the letter punches need to be 4.8mm high, and be clearly marked. They are around £30 on eBay, it's a bit like the ones the police used to use to stamp your postcode into your bike frame. This can get riveted on under the bonnet somewhere handy. No axle weights were required. Just enter manufacturer, then the chassis number. So it seems a sticker is all that's needed for this. No engraving or indentation needed. Just printed it out on a printer and stuck it on. Job done.
Post by hammy3601 on Sept 8, 2018 20:15:58 GMT
Alternatively, make your own. I think that the letter punches need to be 4.8mm high, and be clearly marked. They are around £30 on eBay, it's a bit like the ones the police used to use to stamp your postcode into your bike frame. This can get riveted on under the bonnet somewhere handy. No axle weights were required. Just enter manufacturer, then the chassis number. So it seems a sticker is all that's needed for this. No engraving or indentation needed. Just printed it out on a printer and stuck it on. Job done. Im not sure but I dont think a sticker is good enough. Don't quote me on that though mate
jayz101
Junior
Brake time
Post by jayz101 on Sept 8, 2018 20:27:15 GMT
So it seems a sticker is all that's needed for this. No engraving or indentation needed. Just printed it out on a printer and stuck it on. Job done. Im not sure but I dont think a sticker is good enough. Don't quote me on that though mate the IVA guy passed it already. Its possible that this was just lucky but he was fine with it
Post by jleigh5 on Apr 3, 2019 11:31:03 GMT
Hi, I am unable to find a definitive answer to this question, so hopefully someone here can help. How big do the holes in the back of the seats need to be? Do they need to be just big enough to let the harness through, or big enough so that the harnesses don't foul on the seat at all? I assume they can't come round the side of the seat?
Another question: does the loom have to go though the front bulkhead, or can it go over the top? It doesn't foul on the bonnet when it is over the top.
Thanks in advance
Post by jleigh5 on Apr 3, 2019 11:33:18 GMT
Post by ian85 on Apr 3, 2019 11:56:16 GMT
Another question: does the loom have to go though the front bulkhead, or can it go over the top? It doesn't foul on the bonnet when it is over the top. I have gone through the bulkhead like most others, but I can't see why you couldn't go over if that's how you want to do it. Going through is pretty easy with the right hole saw and you can reuse the mx5 rubber grommets
Post by bewgy on Apr 3, 2019 18:46:56 GMT
Check my build I went over the top of the bulk head, it made life a lot easier for me.
Post by jleigh5 on May 9, 2019 9:37:07 GMT
Thanks for all the answers so far - very helpful! I am opting for harnesses, but have bought Bolt-in instead of Wraparound (I want to wrap them around the harness bar). Can I just cut the webbing to remove the bolt-in adapter, or does it need the stitching unpicking? I assume if it is cut it isn't okay to have it all frayed, even if there is more than 100mm left over after wrapping (IVA req).
Also, where is the best place to buy the nut caps? Thanks in advance
Post by Stiggy on May 9, 2019 11:12:27 GMT
you can melt the ends to stop them fraying but stitching is a deffo no no as they need to be E marked and not modified, perhaps the buckle will allow a wrap around if you cut the ends off.
Post by jleigh5 on Jun 19, 2019 9:52:33 GMT
There are a few hoses that I am unsure of where they need to go (pics below). None of the three hoses are attached at the other end. The one on the complete left of the second photo is attached to another regulator the the back of the intake manifold.
I have removed the black canister, so those hoses can go.
I would like to know which ones I can block any off, which ones I can loop together into the intake manifold, and which ones I can attach to the currently unused vacuum regulator.
Thanks in advance
I can add more photos if needed
Post by jleigh5 on Jun 20, 2019 15:36:40 GMT
Am I right in thinking the Hazard lights have to be operational from the driving position? What about Rear Fog lights? Anything else that I am missing? Thanks in advance
Post by hammy3601 on Jun 21, 2019 21:18:14 GMT
Am I right in thinking the Hazard lights have to be operational from the driving position? What about Rear Fog lights? Anything else that I am missing? Thanks in advance My inspector checked I could reach all controls and switches with my harness on. Others havent been asked that but the rule book says you must be able to use them all whilst driving. Im currently working on my dash redesign which I factored in to my build
1055
Newbie
Post by 1055 on Jun 24, 2019 18:48:41 GMT
FWIW, there are many SFI harness manufacturers that make bolt in harnesses, that can also be utilized as wrap around. such as these G force units. they are SFI 16.1 and FMVSS 309, both of which are sewn onto the tags on the belt. critical here, not sure about the UK. www.jegs.com/i/G-FORCE/471/6000RD/10002/-1
Post by p2tav on Jun 25, 2019 7:22:13 GMT
Am I right in thinking the Hazard lights have to be operational from the driving position? What about Rear Fog lights? Anything else that I am missing? Thanks in advance My inspector checked I could reach all controls and switches with my harness on. Others havent been asked that but the rule book says you must be able to use them all whilst driving. Im currently working on my dash redesign which I factored in to my build my inspector checked he could reach too but I used seatbelts so was easy for him to reach I have harness bar too but day to day use seat belts as much easier for road use.
