Post by fasteddie on Jun 5, 2011 15:17:43 GMT
Hi Jeff, thanks for the praises, had visitors over the weekend so not able to photo details as per your requests but I promise, first chance I get I will do so. Having seen CKC exocet at Stoneleigh and spoke to John thingyens on the stand I wouldn`t recommend the flush fitting Aero latches as John had a nightmare trying to do the cutouts without chipping the fiber glass and that lads an expert. They do look good and we have used some pipe clips as hinges for the bonnet. I will post pictures as soon as possible. Do not forget to replace the water pump as they are prone to going if your donor has been standing for some time and so easy to do before you put new chassis on. regards Ted. P.S. Copying is the best form of flattery.
Post by fasteddie on Jun 5, 2011 15:20:04 GMT
Funny moderators, would not allow me to put John last name in which is D I C K E N S. see if thats fooled the old duffers.
Post by tlight on Jun 5, 2011 18:58:53 GMT
Hi Jeff, thanks for the praises, had visitors over the weekend so not able to photo details as per your requests but I promise, first chance I get I will do so. Having seen CKC exocet at Stoneleigh and spoke to John thingyens on the stand I wouldn`t recommend the flush fitting Aero latches as John had a nightmare trying to do the cutouts without chipping the fiber glass and that lads an expert. They do look good and we have used some pipe clips as hinges for the bonnet. I will post pictures as soon as possible. Do not forget to replace the water pump as they are prone to going if your donor has been standing for some time and so easy to do before you put new chassis on. regards Ted. P.S. Copying is the best form of flattery. I agree with Eddie on the flush fitting aerolatches, fitted them on my bonnet, would recommend the proud fit solution. Tim
blobnnob
Junior
Dex at Curborough 2011
Post by blobnnob on Jun 6, 2011 20:34:46 GMT
Hi. That sounds good advise about latches, thanks Ted and Tim, already done water pump n timing belt, cheers. Lookforward to seeing pic's when you get chance. Any one got measurements for position front lights. Fitted heater we got from MEV today just got to figure away to make some ducting to keep our feet warm. All the best Jeff
Post by fasteddie on Jun 9, 2011 19:17:11 GMT
Hi Bloby, tell you what, the amount of heat generated by the engine and radiator I think if you could devise a simple vent just underneath the rear of the bonnet then deflect it down, your tootsies will be like toast. You just need some simple flap to block it off in the summer.
Post by tristan on Jun 24, 2011 16:11:46 GMT
Hi, Do you have some pictures of how you made the fuel entry on top instead of on the side? KR Tristan
Post by fasteddie on Jun 24, 2011 16:31:38 GMT
Hi Tristan, your english is superior to my Flemish. It`s a bit difficult to take a picture as it`s quite involved to remove cover, basically I blanked off the original entry with a piece of original fuel pipe blanked off with a brazed end cap short piece of hoseand 2 clips. I then purchased an aero cap which came with a funnel shaped receptor which attached to the old carbon canister return which is central to the tank. The height of this is critical as the lip must sit flush with the inside of the rear boot. If your happy to give me your Email address I will get my friend to draw the arrangement and Email it to you, regards Ted
Post by tristan on Jun 24, 2011 16:51:40 GMT
Hi,
Thanks for the quick reply! I will PM you my e-mail adress, looking forward to your information.
By the way, forgot to tell you that I really like your car! my compliments! I am also building an Exocet, (the kit is not yet here but I am busy preparing the Mx5 parts) and thanks to you I got some new ideas for a few things (fuel cap, aerocatch etc)
Thanks again!
Tristan
blobnnob
Junior
Post by blobnnob on Jun 25, 2011 11:58:38 GMT
Thanks Ted, got rear lights done, seats fitted which were a pig, Mk3 but very cheap!! gor her started after switching fuel pipes on fuel rail, we have fuel filler on top with flexible pipe, doing front lights this weekend, were getting there. Heater in trying to figure out how to switch fan from windscreen wiper stalk??? Cheers Jeff
Post by pete on Jun 28, 2011 18:46:01 GMT
hi car looking great i am at the rolling chassis stage. i wonder if you can help me i see in the background of your photos moor mx5,s do you break them im looking for some small parts i wondered if you can help. i have tried ebay but no one comes back to me. Pete.
Post by h5ngs on Jun 28, 2011 21:27:39 GMT
Pete im breaking 2 mx5's at the mo just bought another one off a friend, just let me know what you need and ill see what a can do.
Post by pete on Jun 29, 2011 18:59:46 GMT
hi Eddie is this the right place to be doing this.. i am looking for little right hand brackets that fit on the bulkhead and holds the clutch pipe at the join there is only one on a car but i need two also looking for the banjo union with bolt that fits on the front of brake master cylinder.. cheers Pete.
Post by fasteddie on Jul 4, 2011 17:31:52 GMT
Hi Pete, not really sure what your looking for, we currently have 3 MX5`s which will form the basis of a track day car so lots of spares for sale, send me an email with small sketch or page and part discription from the manual, regards Ted
Post by pete on Jul 5, 2011 17:57:53 GMT
[img src="[/img] "]
Post by pete on Jul 5, 2011 18:20:13 GMT
[/img]http://s1180.photobucket.com/albums/x406/exocet1/
