Post by gwnwar on Dec 30, 2016 23:29:36 GMT
Clutch master.. pull pin for cly. rod to clutch pedal put pin back into pedal unit so you don't loose it.. Remove hard line from cly. 10mm line wrench.. remover cly. from firewall 12mm nuts.Drain put cly and nuts in plastic bag.. remove hard line, rubber hose and clips.
Post by chrisbucks1 on Jan 2, 2017 14:19:41 GMT
Clutch master.. pull pin for cly. rod to clutch pedal put pin back into pedal unit so you don't loose it.. Remove hard line from cly. 10mm line wrench.. remover cly. from firewall 12mm nuts.Drain put cly and nuts in plastic bag.. remove hard line, rubber hose and clips. Thanks so much
Post by chrisbucks1 on Jan 2, 2017 14:19:54 GMT
Post by smithers on Jan 2, 2017 14:28:26 GMT
afternoon guys good to see a few more Bucks guys building exocets. been a while since i finished mine but i still drop in here from time to time, i’m in MK. I’m sure most issues are well documented by now but if you want to have a look at a finished car let me know. This is my car-Running a TD04 turbo with megasquirt. uploading pictures
Post by chrisbucks1 on Jan 2, 2017 14:57:24 GMT
afternoon guys good to see a few more Bucks guys building exocets. been a while since i finished mine but i still drop in here from time to time, i’m in MK. I’m sure most issues are well documented by now but if you want to have a look at a finished car let me know. This is my car-Running a TD04 turbo with megasquirt. uploading picturesJust sent u a private message . Be epic to meet up
Post by gwnwar on Jan 2, 2017 19:35:23 GMT
smithers.. Like the use of the MEV emblem on the nose it pulls the whole front together/flows..easy on the eye.. nice build..
Post by davetherave on Jan 2, 2017 21:00:50 GMT
I just sent you a PM Chris if you want to arrange a meet up I come along
Post by chrisbucks1 on Jan 4, 2017 13:46:13 GMT
Quick question do I need the wiring loom from the doors or can I just throw it away ?
Post by mikeeyboy on Jan 4, 2017 18:09:50 GMT
Can't remember on mine as it's a while since I stripped it. If the side indicators are on it you will need these for iva
Post by chrisbucks1 on Feb 2, 2017 12:03:12 GMT
Before and After.
Post by chrisbucks1 on Feb 2, 2017 12:05:07 GMT
Taking the body off the MX5 tomorrow any advice ?
Post by sheffjohn on Feb 2, 2017 13:27:23 GMT
Taking the body off the MX5 tomorrow any advice ? It's not heavy, but it's awkward. I used an engine crane and lifting chain bolted into the seat mounting points to take the main weight, then just need 1 person on the crane and one at one end of the car to stabilise as you lift. Make sure all earth straps and exhaust rubbers are off, gearlever trims etc.
Post by Fin on Feb 2, 2017 22:21:05 GMT
Think the manual states 14 securing bolts, but being an NB, you may also find 2 extra surprises in the form of this U-shape strap on the rear sub-frame.
Post by chrisbucks1 on Feb 4, 2017 12:52:06 GMT
Post by chrisbucks1 on Feb 4, 2017 12:53:19 GMT
Before I scrap the body .What do I need to remove Exhaust hangers ?? VIN ?? Anything else useful ??
