Post by tlight on Nov 1, 2013 19:41:56 GMT
Side indicator brackets made, mounting Ford Focus clear lens to match the chassis angles.
Post by tlight on Nov 2, 2013 11:38:45 GMT
Post by tlight on Nov 2, 2013 11:47:05 GMT
Fibre glassed with Isopon P40 the speedo clocks into the pod & held with a heavy weight And cured in place
Post by jgilbert on Nov 2, 2013 13:11:26 GMT
Very nice indicator work and good looking dash pod finish. Will really set the car off well. Well done
Post by driver on Nov 3, 2013 12:50:08 GMT
I have the same indicators, great idea but will it pass iva in that position?
Post by tlight on Nov 3, 2013 16:32:06 GMT
I was thinking of turning them through 90degrees for the IVA, or have I missed a trick?
Post by red5 on Nov 3, 2013 19:11:49 GMT
I was thinking the same tim.
Its all about them being seen from the obscure positions behind the car , the are laid down in the manual and need to be checked to be believed ! - in honesty its more about where you get it tested i.e examiner , but im pretty sure they wouldn't pass in Exeter , fail safe locs are up high or on the edge of the front mudguards.
Post by tlight on Nov 4, 2013 18:37:39 GMT
Powdercoated today
Post by tlight on Nov 4, 2013 18:40:27 GMT
Drilled wing stay for ABS mounting Will probably remove dust shield and then get hubs painted and wing stays powder coated
Post by tlight on Nov 4, 2013 21:05:41 GMT
Split the dust shields off the hubs, so ready for shot last, bearing removal & paint. Made a template for mounting the dash board pod Which will make a bracket that will look a little like this So finished article will hopefully look a little like this... When all screwed in place and squared up - Fingers crossed !
Post by tlight on Nov 5, 2013 20:42:28 GMT
Rear wing stays drilled, rounded off and powder coated
Post by tlight on Nov 5, 2013 20:44:03 GMT
Dashboard bracket made And layed n place Trial fit next, adjust & powder coat
Post by tlight on Nov 5, 2013 20:55:58 GMT
Rear hubs shot blared today & new bearings installed. Photos to follow.
Next jobs finish rear indicator brackets, mount.
Then paint drive shafts & complete rear drive line with new CV boots.
Post by jgilbert on Nov 5, 2013 21:33:03 GMT
Hehe. Loving the cardboard template work. Best bit about building our car has been making up designs in card and then scrapping them and starting again and improving the design.
Post by tlight on Nov 6, 2013 12:43:46 GMT
Rear Indicator brackets made and powder coated Which will look a little like this
