Post by SeanW on Aug 11, 2016 15:15:13 GMT
Do you need all of those sensors? Why not delete the EGR valve and get rid of that stuff? Actually, that gets me to something I'd wanted to ask you about. You went with MS before you took your Exocet to the BAR? Did you also delete the front charcoal can and EGR beforehand? I do plan on running MS and doing EGR delete eventually but wasn't sure about keeping everything completely stock or not before inspection.
Post by steadfast on Aug 11, 2016 17:14:23 GMT
The BAR cares nothing about that stuff, except for the PCV. You don't need the EGR or the canisters.
Post by SeanW on Aug 11, 2016 22:43:05 GMT
The BAR cares nothing about that stuff, except for the PCV. You don't need the EGR or the canisters. That's going to make things much simpler.
Post by SeanW on Aug 12, 2016 3:50:18 GMT
Okay, had a little free time after work this evening so I made getting the mounts for the fuse block and expansion tank my goal. First, installing the sight tube on the expansion tank. Pretty straight forward, photos basically say it all. Measure .5 inches up from the lower and upper rims, mark, and drill to 1/2 inch. (I started with a 1/8th bit to make pilot holes, finished to with a stepped bit.) Then I turned the stepped bit lose making holes to rivet the brackets in place before mouthing everything up. Annoyingly the catch can uses 1/4-20, since I don't have a set of ratcheting SAE box-end bolt the can to the bracket was a small pain. My dog, Jayne, was throughly bored with me messing around with the car rather than taking he for walking immediately after getting home from work.
Post by SeanW on Aug 13, 2016 14:40:31 GMT
Didn't do a lot last night but after getting home from a movie (Suicide Squad) I spent 45 minutes or so fabbing a basic bracket to keep the intake from flopping around the bay. Will do until turbo time. Also, I am coffee trash.
Post by SeanW on Aug 15, 2016 18:23:47 GMT
Post by SeanW on Aug 16, 2016 19:46:19 GMT
This feels like such a terrible mess right now just to get the car to a point that I can I can turn it over. I can't wait to begin stripping out everything from the loom that I won't need. Thankfully I have a color version of the 97 wiring diagram from the factory service manual, which has been helping a lot. Unfortunately there are a couple of places where it tells terrible lies. Still, making progress!
Post by steadfast on Aug 17, 2016 2:04:21 GMT
How about a start up video!
Post by SeanW on Aug 17, 2016 5:26:02 GMT
How about a start up video! Soon! Can't get too deep into the project this week because I'm pulling an on-call rotation. The past couple of days have been a bit busy fielding afternoon/evening calls.
Post by SeanW on Aug 18, 2016 5:22:27 GMT
So, I'm scratching my head at two mystery connectors in my engine bay. Some how they didn't get labeled in the tear down. First is this guy: My FSM wiring diagram suggest that it could be the engine coolant temp sensor (based on the wire colors) but I can't for the life of me find anywhere it might plug into. Anybody known anything about this connector on 97 1.8l Miata? Then there's this little dude: The manual suggest that thing (single wire, blue/yellow stripe) is the power steering pressure switch. My donor didn't have power steering. Any info at all would be hugely appreciated!
Post by SeanW on Aug 18, 2016 14:57:22 GMT
I'm also trying to figure out the best way to run wires for the secondary O2 sensor Right now I'm thinking it'll probably be easiest/best to extend the leads and run it down the tunnel rather than drilling out a hole in the tunnel for the O2 sensor's pig-tail/grommet. (Similar to the stock miata)
Post by zeitgeist on Aug 18, 2016 20:21:26 GMT
That is the Power steering switch for the single wire. Harnesses are not specific and often have options that aren't used included which sounds like the case for your P/S. I ran my second O2 sensor wire down the tunnel and zip tied it to the PPF to keep it away from the driveshaft. Works well and less visible wires from the top.
Post by SeanW on Aug 21, 2016 3:01:25 GMT
Post by steadfast on Aug 21, 2016 3:09:55 GMT
There is your problem, that twist tie was grounding out the circuit! I bet you'll have it started by tomorrow.
Fuel? Spark? Grounds (all of them)?
Post by SeanW on Aug 21, 2016 3:33:37 GMT
There is your problem, that twist tie was grounding out the circuit! I bet you'll have it started by tomorrow. Fuel? Spark? Grounds (all of them)? Fuel. As in I had none in the tank. Really wanted to check to see if would crank, which it does! I'll put some gas in the tank tomorrow morning and see it'll turn over and idle.
