Post by mikeeyboy on Jun 16, 2017 20:52:18 GMT
Stick with it. Just seen your signature, I have the same donor, will trace those cables for you tomorrow.
Post by mikeeyboy on Jun 20, 2017 21:13:29 GMT
This one is down by the drivers side front light connections black wire and light green with black stripe wire On my loom I have this labelled as "not connected"This one is also right at the rear and isn't the lights or fuel connections block has: black wire, black with brown stripe wire, black with white stripe wire loose wires are brown with white stripe and a grey Not required, I cut it out. It is labelled as Rear window heater, had a coiled cable plugged into it.
Post by mikeeyboy on Jun 20, 2017 21:15:29 GMT
I have only just managed to find 10 minutes to look at some of these, picked these 2 off in 5 minutes. I need to move some bits around to do the other ones so hopefully can trace them tomorrow night.
I really wouldn't stress about them too much. Its surprising how many are not needed.
Pretty sure I should be able to identify the rest fairly easily when I can find a half hour.
Post by hutchey on Jun 30, 2017 7:40:41 GMT
I have only just managed to find 10 minutes to look at some of these, picked these 2 off in 5 minutes. I need to move some bits around to do the other ones so hopefully can trace them tomorrow night. I really wouldn't stress about them too much. Its surprising how many are not needed. Pretty sure I should be able to identify the rest fairly easily when I can find a half hour. Cheers Thanks Mikeeboy, I get my evenings back in another 2 weeks and hope to be cracking on with my lad on getting this done and all my welding stuff done ready to go off for powder coating.
Post by rv8air on Jun 30, 2017 19:05:40 GMT
These projects are promoted with a short build time. Part of the appeal, I guess. However, there's a big difference between build time, and the head-scratching time required before actually building something. I've had pretty good success on other projects, by putting whatever's got me stumped at the moment, aside for a couple of days. Sometimes a really good solution will just pop into your head. Hang in there.
Post by buildercg on Jun 30, 2017 20:47:34 GMT
These projects are promoted with a short build time. Part of the appeal, I guess. However, there's a big difference between build time, and the head-scratching time required before actually building something. I've had pretty good success on other projects, by putting whatever's got me stumped at the moment, aside for a couple of days. Sometimes a really good solution will just pop into your head. Hang in there. I completely agree with this. In my case, "head-scratching" was probably close to 50% of my build...and it continues now that I'm forced to work on the engine. 25% was "changing my mind" and the remainder was actually doing things that worked out!
Post by mikeeyboy on Jul 1, 2017 8:56:37 GMT
I'm going to have an afternoon in the garage today so will look to trace the rest of the cables for you.
Post by hutchey on Jul 11, 2017 7:43:38 GMT
A few more days and we can get back into the garage and finish making our brackets and welding them up. Then the damn wiring loom.
Post by hutchey on Jul 17, 2017 15:48:22 GMT
Well that wasn't much fun, still drawing a blank on some of these remaining wires. Moving on to some welding now, just had enough of damn wires. And as for that damn air box and all its bits..................
Post by gwnwar on Jul 17, 2017 17:26:30 GMT
What wiring parts are giving you a fit now.. Did you find all the connectors you posted before.. Not trying to be funny you aren't color blind are you for reading wire color.. I have seen that before.. What is problem with air box.. I would get it running then mod it.. Didn't pat out yet on the wiring..
Post by hutchey on Jul 17, 2017 20:02:26 GMT
Hi, I am way overdue an eye test but am just struggling with all these fiddly little wires! Still got most of the same unidentifiable as before on page 12.
2 blocks one white one black Wires are: black with brown Blue Black with blue Pink
Big white block at rear of console: Orange Grey
White connector by bulkhead: Black with yellow (comes from diagnostics) Brown with white Black with yellow other end Grey
Connector wrapped in foam near ECU Green Light green Brown Orange Grey Brown with white
White connector: Pink Red with white Black with blue
Post by hutchey on Jul 25, 2017 16:14:35 GMT
Hi, are the wiring looms wildly different between mk1, mk2 and mk2.5?
Post by hutchey on Jul 27, 2017 8:24:03 GMT
Well I finally had a lot of joy on the wiring loom bits yesterday. Thanks to a lot of you on here with your replies and pictures, I now have a strimmed down loom that looks like this: I have 2 queries left on the loom and these are the white block that is at the back of the car with 2 wires in it and what to do with these wires that connect to the charcoal cannister thing? upload a pic on the internet
Post by buildercg on Jul 27, 2017 15:41:51 GMT
Wires for the charcoal canister are to control opening and closing the valve. If you're keeping the canister then you need to keep it. I don't know about the other connector.
Your loom it looking a lot like mine did at one point not very long ago. Don't wrap it anymore until you know everything is working otherwise you will waste a lot of tape, time, and self-patience. Careful with the computer resting unsecured on the frame like that. One big bump and you could be looking at a lot of money to get a replacement.
Post by hutchey on Aug 16, 2017 17:55:14 GMT
Thanks to many here, our wiring loom is sufficiently stripped now. Sadly, my broken hand has now got in the way of progress but we hope to get some easy earth points done and the fuel lines reconnected temporarily to see if it will start an run. We have pilot drilled most of the holes for the wiring loom clips, brake lines and so on and we need to make and weld on brackets for the power steering bottle and the coolant bottle. Then get the nose cone bracket in place and trail fitted. If all that goes to plan then it's save up for the trip to the powder coaters...................
