Post by sparkyman403 on May 27, 2016 20:31:47 GMT
Shows up my end as sent it just said you could phone me
Post by sparkyman403 on May 27, 2016 20:32:41 GMT
07786600050
Post by Shane on May 31, 2016 18:02:01 GMT
sorry didn't get back to you mate, ended up spending the weekend with the family not the car will give you a bell this weekend though! Im hoping to get a lot done this weekend: 1. Take chassis back off 2. Pclip brake and fuel lines to bottom of chassis 3. Measure, cut and fit side panels. 4. Refit Chassis 5. Remove wheel hubs and fit the stays Wish me luck
Post by sparkyman403 on May 31, 2016 18:46:57 GMT
Ok no problem any time is good
Post by p5curly on May 31, 2016 20:37:49 GMT
Did you find some petrol pipe then I hope Dave was of some help when he visited you
Post by miket on May 31, 2016 21:17:20 GMT
Re. your weekend Plan pt 3: I'm planning to leave the side panels 'til pretty much last so as to keep access. Not sure how far on you are with each item but seats, belts, battery, instrument cluster are all that bit easier without side panels in the way?
Post by ian360 on Jun 1, 2016 8:28:28 GMT
+1 on Miket. Haven't even unwrapped mine yet. Guess you have the new chassis and its all pretty tight so leave as much access as possible. You don't need to remove the rear hubs to fit the stays - do you have ABS as will need to make a new bracket to fit the rear stays if so?
Post by Shane on Jun 1, 2016 19:29:36 GMT
Good advice about the side panels, will leave them off the list for now, wont be removing the rear hubs just the front and no ABS I changed my mind at the last minute about the fuel line and brought 8mm Kunifer (copper/nickel) as its supposed to be harder wearing than standard copper. Turns out most "8mm" pipe is actually 5/16inch which is 7.94mm but i special ordered actual 8mm just to be on the safe side (probably a waste of money, but worth the piece of mind)
Post by jwagner on Jun 1, 2016 21:44:10 GMT
Cunifer is the right stuff for a car and copper/nickel alloys are used by several OEMs. Copper work hardens and breaks so I wouldn't use it for anything that makes a difference like brakes or fuel.
Post by Shane on Jun 4, 2016 15:37:55 GMT
Advice for anyone not yet brought a donor, spend extra money to get a newer/not so rusted one! Simple task of taking 3 bolts out to fit the front stays ended up with all 3 bolts snapping off in the hub! Tried removing them but made things worse, so ive just ordered another hub assembly (not new but hopefully not as rusted) I finally got the fuel and brake lines on, again a simple task that took hours - trying to find the right size tappers and drill bits No where near enough self tappers and P clips with the kit, not sure why it doesn't come with a pack rather than a few counted out in bags. Same with the supplied brake line, rather than just giving a whole line (25ft) you get half, which means your short running a length across the rear sub frame and to the wheels and for the cost of the 25ft 5/16" copper its really not worth the hassle cutting it in to 2 lengths! Oh well, making progress, very slowly
Post by NJ. on Jun 4, 2016 16:03:04 GMT
Looking good Shane. Following with interest as we're planning the same colour schemes I think...
Post by Shane on Jun 5, 2016 8:04:24 GMT
Thanks mate, I'm loving the white chassis, no doubt I'll be getting the bonnet out at some point to see how it looks, I'll posts some pics when I do.
Post by Shane on Jun 5, 2016 11:12:07 GMT
GOOD NEWS! The driverside front hub cam off no problem Need to pick up some longer bolts now to get the stays connected and were away!
Post by Shane on Jun 8, 2016 13:43:10 GMT
Feeling annoyed and disheartened
Has anyone else had the luck im having?
The new secondhand knuckle came today and I went to fit it to realise it didnt come with the lower ball joint (obvious really) I tried to remove the ball joint from the current knuckle and guess what, the bolt snapped! So ive now had to order a new lower ball joint.
Why cant anything go to plan lol, I WILL get these bloody wing stays on!
Post by miket on Jun 8, 2016 15:15:53 GMT
Yeah, know that feeling! But looks like you're not going to give in easily!
If want to spend time rather than money there's always drilling and easyouts?
