Post by latemarch on Sept 21, 2010 0:11:14 GMT
Just wondering if it can be backed. Otherwise it'll be a problem in the parking lot.
Post by roadtrackrace on Sept 23, 2010 5:54:38 GMT
We are currently building a tr1ke for a 78 year old guy who wants a reverse. so are installing one for him behind the passenger seat.
It's so incredibly light though (just over 300kgs) that it's very easy to push around. Even easier than a big bike in fact as there is no balance issue.
RTR team.
Post by latemarch on Sept 23, 2010 17:43:26 GMT
Thanks for the reply. Will the solution used for the other customer be offered as an optional accessory for the kit? I know that I'd sure like that as well.
Post by vmvcars on Sept 23, 2010 17:49:08 GMT
What are you doing for reverse? Putting a starter motor in-line with the chain? I have seen that on a few bike powered cars.
Post by edwinwl on Jan 30, 2011 21:50:37 GMT
Post by latemarch on Jan 31, 2011 0:33:38 GMT
That looks interesting I wonder if there's room in the kit for it.
Post by latemarch on Jan 31, 2011 0:55:33 GMT
After looking at that some more.......I think that's a Subaru starter.
All you might need is the reverse gear which appears to screw on to the output shaft in place of the nut and then an appropriate mounting plate.
Post by Deleted on Jan 31, 2011 11:07:05 GMT
I looked at this option a while ago, but after seeing the TR1KE 2 weeks ago, I suspect there is not enough workable room to mount it, as it comes in from the left and the rear part of the frame comes in at that point making it very tight to mount a suitable sturdy mount.
vtR1k
I'm a trike lover...
Post by vtR1k on Jan 31, 2011 18:55:29 GMT
I just sent an email to them, asking for some pics of the thing mounted. I need a reverse because I'm missing one leg. Also thought about the Flintstone option, but that will be the last option I am going to install...
vtR1k
Post by vtR1k on Jan 31, 2011 19:31:22 GMT
Got an anwer:
I'm wondering if it fits... Any ideas?
Post by edwinwl on Jan 31, 2011 19:49:31 GMT
That looks like a proper solution! (The Flintstones solution is also not preferred by me.)
Post by latemarch on Jan 31, 2011 22:49:10 GMT
Instead of a gear at the primary drive maybe could use a second chain drive to another spot where a sproket and gear drive could sit and the starter drive it from there.
vtR1k
Post by vtR1k on Feb 1, 2011 7:50:38 GMT
The point is that it is necessary to have the reverse gear in a neutral position when it is not activated. With a startermotor, which has a bendix, and a gearwheel on the primary shaft it will "disconnect" itself when deactivated. I think it will be difficult to create something with an extra drive chain and sprocket...
Post by edwinwl on Feb 1, 2011 11:34:57 GMT
My opinion is that this is a relevant option for RTR to offer, when ordering a Tr1ke. So RTR can check if the items works.
Post by Deleted on Feb 1, 2011 11:44:45 GMT
I think you might find there is not enough room to mount this as an option on the TR1KE, because the rear part of the frame comes in at that point, I had looked at LYNX before, and they sent me these pics, but when I was down at RTR looking at the trike with there custom reverse, there appeared to be not enough room to mount this unit onto a substantial mounting plate, in my opinion, this is one of the better options, but the room to fit it will be the problem.
I will defo be making some sort of reverse option for mine. And I will post the ideas and pics on my website.
