Post by slugshot on Aug 8, 2015 7:48:58 GMT
Here's a couple of pic's of my new exobusa kit waiting for me to attack it, don't think it'll be ready for Skeggy though
Post by james13009 on Aug 8, 2015 11:03:11 GMT
Good luck
Post by Deleted on Aug 8, 2015 12:59:08 GMT
Slacking off!
Post by slugshot on Aug 8, 2015 13:20:43 GMT
Yes ads but the weathers nice and I've got a tR1ke that needs a good thrashing,
Post by slugshot on Aug 12, 2015 18:14:04 GMT
The drive shafts and chain driven diff came today which was a quicker turnround than I expected so no excuse now for me to not crack on and get it built
Post by Deleted on Aug 14, 2015 21:15:51 GMT
Is it built yet?
Post by slugshot on Aug 15, 2015 8:42:18 GMT
Lol, I've actually not laid a spanner on it yet mate. Its all in the planning don't you know, I'm hoping to build it without pinching too many bits off the tR1ke so I can keep it on the road.
Post by slugshot on Aug 29, 2015 20:01:14 GMT
A quick update on the build so far, nothing actually bolted to the chassis yet but plenty of parts being made ready for when I do. This is a pic of the wishbones that I've just powdercoated using my Electrostaticmagic diy kit and a cheap second hand electric oven. I also coated the rear uprights, these are at a mates having the wheel hub bearings pressed in. Also a refurbed sierra rack came today, I have a quick rack conversion ready to slot in.
Post by slugshot on Sept 6, 2015 20:56:11 GMT
Did a little bit of work on the exobusa this weekend, drilled the fixing holes for the floor but not going to fix it until later in the build. Also mounted the steering rack and the quaife diff and got the bearings pressed into the rear uprights. I'm not happy just relying on the 4 fixings for the diff mounting plates, I think there's a good chance the whole thing could easily move in the slotted fixing mounts. So will weld some 8mm threaded bosses either side to stop any movement and will also help doing chain adjustments.
Post by slugshot on Sept 16, 2015 20:27:37 GMT
Was planning on dropping the motor mounts to take advantage of the shallow dry sump but decided not to bother. If it was going to be used as a full on race car then the 35mm I could lower it by would be worth the effort, but i'll make do with just dropping the ride height when on track days.
Post by OzExoNinja on Sept 18, 2015 13:11:47 GMT
Hi mate, you may already be aware of this but Stuart pointed out to me today that Exo have left out two important pieces of bracing from our chassis and I just wanted to be sure you were aware whilst yours was still able to be corrected.
Mark.
Post by slugshot on Sept 18, 2015 19:49:44 GMT
Thanks for the heads up, yes I did see the posts earlier today. I'm not convinced it really needs any extra bracing but even if I did add some it definitely won't be positioned where stuart has suggested, lol.
What dimensions do you need from the rear drive shaft setup, I can take measurements off mine if it helps speed things up.
Can't you just line you diff + rear sprocket up with the engine sprocket, that'll give you the lengths you need for the drive shafts.
Post by james13009 on Sept 18, 2015 20:18:48 GMT
Slow down with the build please. I'm going to feel less of a man if you over take me. Which you probably will
Post by james13009 on Sept 18, 2015 20:19:56 GMT
How comes you've changed you engine drive sprocket or is it super clean?
Post by slugshot on Sept 18, 2015 20:52:09 GMT
How comes you've changed you engine drive sprocket or is it super clean? I changed the sprocket from a smaller one to raise the gearing because the diff has a lower geared sprocket than I ran on the tR1ke plus I'm running 15in wheels not a 17in as on the tr1ke. Did you sort your chain length, if not 70 links.
