Post by greg on Jan 24, 2016 2:33:29 GMT
Very cool!
Post by nigel on Jan 24, 2016 10:11:14 GMT
I really like the styling look but I just wonder if by recessing the light cluster that you may have restricted the angle of visibility to an extent that the authority's, when coming to registering, object. nigel
Post by golden86 on Jan 24, 2016 16:31:18 GMT
I really like the styling look but I just wonder if by recessing the light cluster that you may have restricted the angle of visibility to an extent that the authority's, when coming to registering, object. nigel I see you're in the UK, and i appreciate the heads up, but I'm in Illinois. Here in Illinois, the state doesn't care what you do as long as they get their money. The lights are plenty bright to be seen from any angle
Post by golden86 on Jan 26, 2016 1:14:46 GMT
The powdercoater is jacking me around. He called me on Saturday to say the frame will be done on Sunday at 3pm. I show up at 3 on Sunday and nobody was there. I call him, no answer. I called him this morning, no answer. I show up at his shop at 3pm today, and nobody there again. I'm not quite sure what to do, I guess I will keep trying. On another note I decided to work on brake/fuel line mounts. I didn't like the idea of a million P-clips drilled into my frame, so i picked up some 3/8"x3/4" aluminum stock. I drilled a few holes to hold the lines, and another hole so I can through bolt it to the frame. now I only have one hole to drill per bracket. Here is a quick rundown of what I did. I started off with two pieces of aluminum I then drilled two 5/16 holes for the fuel lines, and a single 3/16 for the brake. I then flipped it to drill a hole for the bolt Here is is opened up Here is is with a few pieces of scrap tubing so you get the idea That's all the progress for now until I (hopefully) get my frame back.
Post by golden86 on Jan 26, 2016 22:48:25 GMT
SEATS! Kirkey Pro Street Drag in 16". These, I can say, are the most comfortable racing seats I have ever sat in, they fit me perfect.
Post by boileralum on Jan 27, 2016 0:25:34 GMT
On another not, does Exomotive supply the fuel line, I didn't see it in the shipment. I bought the braided kit but still got a coil of the cunifer line. It was in 2 USPS boxes that were flattened out and taped together. If you are heading to Indy any time soon you can have it.
Post by golden86 on Jan 28, 2016 2:13:37 GMT
Thanks! I really appreciates the offer, but I already picked up some aluminum tubing a while back.
Post by gwnwar on Jan 28, 2016 5:26:11 GMT
golden86 what are you using aluminum tubing for??
Post by golden86 on Jan 28, 2016 20:38:33 GMT
Post by golden86 on Jan 31, 2016 20:48:24 GMT
FINALLY! I picked up my frame from the powdercoater. Black with a gloss clearcoat. I started installing the floors and brake/fuel lines That is about it for today, hopefully tomorrow I will have it right side up and bolted down.
Post by dietcoke on Feb 1, 2016 15:22:25 GMT
Those lines look good, a lot neater then mine, lol.
Post by golden86 on Feb 7, 2016 22:41:40 GMT
Post by golden86 on Feb 14, 2016 20:27:39 GMT
Post by boileralum on Feb 15, 2016 3:42:50 GMT
Wow Mike, you are making quick work of it! I feel like a lazy bum for not getting much of anything done this weekend, but it was just too cold in my detached garage. I was running my torpedo heater and my upper body was getting warm but my feet were still freezing. I have tomorrow off work, so hoping to get some work done on the car since it will be a nit warmer.
Post by einy on Feb 15, 2016 13:06:59 GMT
I really like how your rear muffler is turning out. I have the Enthuzacar setup in mine, and although it fits nice / sounds good, I'm not crazy about how the 'completely vertical' muffler looks. Yours looks MUCH cleaner!!
