Post by buildercg on Oct 9, 2017 3:46:57 GMT
The last few weeks have been brutal workwise, leaving no time to fix the car. I finally got some time this weekend and was able to go around the car and tighten up the bolts. Two of bolts holding my fender stays and brake calipers were loose. Not a good thing at all and I'm glad I found them when I did. Everything else was tight. I also spent time cleaning up my rear electrical connections. I originally used push connections for everything in the rear end and did each side separate. This made the process of disconnecting and reconnecting the rear lights a royal pain every time I took the rear end off - which has been far more than I would have liked. It took me much of the day, but I completely rewired it and moved the connections to the driver side. Much better. Thank you SeanW for the info and the idea.
