Post by dietcoke on Nov 15, 2015 2:59:55 GMT
Looks similar to what I have now. Small spacer it is. What are you spring rates?
Post by jwagner on Nov 15, 2015 16:24:40 GMT
Springs at that time were HR Race on Koni yellows, so near stock rates. Way too soft with a lot of travel, so that might have had something to do with it. We got the clearance problem first time out on an autocross course. Currently Vmaxx sport with Holeshots.
Post by dietcoke on Nov 15, 2015 23:51:51 GMT
Travel will kill you for sure without spring rate.
Post by dietcoke on Nov 17, 2015 4:02:41 GMT
Working on turning the cluster of gauges into a finished product from the makeshift tach and heap of wires I had before in order to make the last race of the season. Getting the large tach seated in here was quite difficult, due to the curve of the cluster hood - I cut a very interesting teardrop shape in order to sink it in enough to grab and secure on the inside - and slipped once with my bastard file, as you can see. Will work on polishing that scratch out tomorrow, and mounting this. I added some epoxy in a couple places, so I have to let it cure before I try to mount it.
Post by greg on Nov 17, 2015 12:37:06 GMT
Are you going to run a GPS speedo or any speedo of sorts?
Post by dietcoke on Nov 17, 2015 13:58:47 GMT
I may get a gps speedo eventually. The t56 makes speed easy to brain with the ratios in the car. Fourth gear (1:1) is 20mph per 1000 rpm. 5th gear is 30mph per 1000 rpm (.74:1) 6th gear (.5:1) is 40mph per 1000rpm.
Post by greg on Nov 17, 2015 15:41:48 GMT
Ah good point. Didn't realize that. I would save the $$ and just brain it too if the state would accept it.
Post by dietcoke on Nov 18, 2015 19:59:38 GMT
Post by autopaga on Nov 18, 2015 23:29:13 GMT
Is it from BMW E30? How thick it is? Do you band in some place or it is in original shape?
Post by dietcoke on Nov 19, 2015 3:05:32 GMT
E30, original shape. It's 25mm thick.
Post by autopaga on Nov 19, 2015 16:47:07 GMT
It looks that it isn't from e30, it is from e36 (next generation of bmw 3). I will try fit it into my miata.
Post by dietcoke on Nov 19, 2015 18:06:41 GMT
This one's from a 1992 325i, so E36. yeah
Post by autopaga on Nov 19, 2015 21:27:52 GMT
The adapter bars are a final version or only for fit testing? In my opinion they are a little to thin.
Post by boileralum on Nov 20, 2015 21:46:29 GMT
Agreed. I don't think that is going to work well. Stock miatas are known to tear out their stock mounts, and they are far sturdier than that.
Post by dietcoke on Nov 21, 2015 1:04:59 GMT
No, they are not. Miata mounts are 16ga. This is probably twice as strong as a stock miata mount, and that's just the mockup.
I"ll post a pic of the final piece shortly, it's 5/16 thick plate steel and boxed to the chassis tube.
