Post by gwnwar on Jun 2, 2016 5:59:04 GMT
With OEM rings there is a R on the top and 2nd ring it must be in top side. The 2nd ring must be install with the scraper facing down. Install the oil ring spacer wiggly part with the ends of it up.. Upper and lower oil ring rail (smooth) are the same with no top/bottom.. Rails set into a tang in spacer part not all the way to the back of the grove. oil good and must be able to turn both ways.. Did you scrape/clean each ring grove out before installing new rings.. What is the end gap of the rings?? top 0.006>0.011 2nd 0.012>0.017 oil rail 0.008>0.027 Did you put new valve seals in?? You are using dino oil 30 HD for break in right not synthetic right..
Post by Luke Anker on Jun 2, 2016 21:53:08 GMT
Ah yes, there was a dot on our rings indicating they are to be facing up. We made sure of that.
Post by Luke Anker on Jun 2, 2016 21:55:50 GMT
Gwnwar,
I will have to check the ring gaps later but we were within spec when putting them in and had to file a little as well. I JUST had the head rebuilt and valve seals were done at that time. (Not to mention you wouldnt see that amount of smoke with valve seals leaking). Also yes, DINO oil. I will have a new update ready at the end of the weekend
Post by USStu on Jun 3, 2016 3:34:56 GMT
What was your break in procedure for this engine?
Post by steadfast on Jun 3, 2016 4:14:04 GMT
I think it started smoking from the moment it was started the very first time.
Post by gwnwar on Jun 3, 2016 6:16:43 GMT
How long did you run the engine after rebuild before pulling it..
Post by Luke Anker on Jun 6, 2016 15:55:35 GMT
Hello, Quick update. Engine has been pulled, disassembled, pulled rings and replaced them with some brand new SEALED POWER E551KC piston rings. As of yesterday the engine is fully reassembled and just needs to have flywheel and clutch added back on and then it's back in the Exocet she goes.
Post by Luke Anker on Jun 24, 2016 17:07:10 GMT
Alrighty everyone! Large update: Exocet engine is back in, all pinned up, brakes are done, I've gone through my "safety checklist" which is essentially going through with my torque wrench and re checking the specs of everything. I've done a lot of doughnuts in the dirt backroad near my house. Next step is to go to DMV and pay them $$ and start my reg process! Time to hit the road
