Post by sammy on Jan 15, 2017 20:58:43 GMT
Since we are on the handbrake theme, A photo of What present for my car. Aluminum aircraft coming skeleton. POM black handle, While everything else and titanium. I am consoled least Know That the original brake from which the copied weighs about 850gr. For the rest it treats solo Uno waste of time and money. But, 500 grams They .... 2 pounds I ... and perhaps reach my objective. The Light more possible.
Post by sammy on Jan 15, 2017 21:17:24 GMT
in the meantime I took a bit of familiarity with the TIG welding of aluminum. I started with a chatch tank. Will follow the petrol tank of about 40 liters. And I dared to build my propia pedals to measure. But still I am not satisfied with some profiles. Currently too little time for these things ..
Post by kiwicanfly on Jan 16, 2017 2:07:37 GMT
If i understand correctly you have removed the stainless steel ratchet plate and cut the teeth directly into the aluminium BUT used aircraft aluminium instead of normal.
Also you have used a plastic handle instead of an aluminium one.
Result is a saving of around 500g.
Is the carbon one not lighter still?
Post by sammy on Jan 16, 2017 6:22:39 GMT
not exactly. Photo 1: POM pieces Photo 2: aircraft aluminum pieces Photo 3: Grade 5 titanium parts if I would have used aluminum for toothed pieces were worn in no time. Although he would have weighed even less. With carbon, I found that the weight does not differ much. I used two millimeters thick aircraft aluminum. while the basic design of 5 mm piece of carbon. the weight and the same. if I'd use 2mm thick for carbon and high aluminum big twists that I used. well what for aesthetic reasons do not intend to use carbon for the interior.
Post by james13009 on Jan 16, 2017 18:24:11 GMT
God I love this build. 👍😜😵
Post by sammy on Jul 26, 2018 7:18:55 GMT
I've been asked more than once about where my building is. I want to respect the Mev forum and not post anything that does not concern Mev models. Let me just say that for those interested can see on Instagram at the entry: fury evolution. It is only about sharing ideas and solutions that can be useful on both sides. Even if this should disturb someone, I ask forgiveness and the correct cancellation of this current message of mine
Post by kiwicanfly on Jul 26, 2018 8:28:58 GMT
Post by sammy on Jul 26, 2018 9:36:55 GMT
in fact I have not read this post that clarifies what I believed instead. unfortunately I do not attend and read more on this forum
